[mapserver-users] Issue with label content for UNION layers
Julian Hollingbery julian at northtech.dk
Tue Dec 10 02:39:20 PST 2019
Hi list,
I’m seeing a strange phenomenon regarding label content for a layer with connectiontype UNION.
A WMS request to the parent layer (including the UNION layer) produces the result I’d expect, but the same request directly to the UNION layer labels all features with the same label.
Correct:
http://172.30.229.42//fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE<http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
Wrong:
http://172.30.229.42//fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE<http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
The reponses can be seen here: https://www.dropbox.com/sh/121shf8djnx3b3d/AAAApGTLfcuga_mXWDaWFsKQa?dl=0
Any thoughts?
Best Regards,
Julian
MAP
    NAME "danske_stednavne"
    EXTENT 120000 5900000 1000000 6500000
    MAXSIZE 10000
    OUTPUTFORMAT
        NAME "png24"
        DRIVER "AGG/PNG"
        MIMETYPE "image/png; mode=24bit"
        EXTENSION "png"
        IMAGEMODE "RGB"
        FORMATOPTION INTERLACE=OFF
    END
    PROJECTION
        "init=epsg:25832"
    END
    DEBUG 0
    CONFIG "ON_MISSING_DATA" "LOG"
    FONTSET "fonts/fontset.txt"
    WEB
        METADATA
            "wms_srs" "EPSG:25832 EPSG:4326 EPSG:4258 EPSG:25833 EPSG:32632 EPSG:32633 EPSG:4093 EPSG:4094 EPSG:4095 EPSG:4096 EPSG:3395 EPSG:3857"
        END
    END
    LAYER
        NAME "landskabsform"
        TEMPLATE "blank.html"
        LABELITEM skrivemaade
        STATUS DEFAULT
        TYPE polygon
        CONNECTIONTYPE UNION
        CONNECTION "oer_store,oer_mellem"
        METADATA
            "wms_srs" "epsg:25832"
        END
        PROJECTION
            "init=epsg:25832"
        END
        STYLEITEM "AUTO"
        # Define an empty class that will be filled at runtime from the color and
        # styles read from each source layer.
        CLASS
        END
    END #LAYER
    LAYER
        NAME "oer_store"
        INCLUDE "./danske_stednavne_post_include.map"
        DATA "geometri from stednavne_nohist_l1_wms.oer_store using unique objectid using srid=25832"
        TYPE polygon
        STATUS OFF
        LABELITEM "skrivemaade"
        METADATA
        END
        PROJECTION
            "init=epsg:25832"
        END
        CLASS
            STYLE
                OUTLINECOLOR 91 91 91
                WIDTH 1
            END #STYLE
            LABEL
                COLOR 0 0 0
                FONT "verdana"
                TYPE truetype
                SIZE 12
            END #LABEL
        END #CLASS
    END #LAYER
    LAYER
        NAME "oer_mellem"
        DATA "geometri from stednavne_nohist_l1_wms.oer_mellem using unique objectid using srid=25832"
        TYPE polygon
        STATUS OFF
        METADATA
        END
        PROJECTION
            "init=epsg:25832"
        END
        CLASS
            STYLE
                WIDTH 1
            END #STYLE
            LABEL
                COLOR 0 0 0
                FONT "verdana"
                TYPE truetype
                SIZE 10
            END #LABEL
        END #CLASS
    END #LAYER
END #MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191210/84ee78c4/attachment.htm>
More information about the MapServer-users mailing list
