[mapserver-users] Upside Down labelling - Rotate Line text 180 degrees
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Tue Feb 19 06:55:16 PST 2019
On 2/19/2019 4:08 AM, Martin Svend Hagerup wrote:
> Hi all
> Using Mapserver to produce maps for navigation applications we need to
> be able to rotate the road labels 180 degrees on the map so when the
> driver is driving south he/she will see the map upside down
> In an ideal world the line segments labels should follow any curvature
> but still be readable when the map is shown upside down.
> Points labels are just rotated 180 - this should is easy – but I want
> to use the many benefits of Angle Auto if possible
> Cheers
> Martin Hagerup, Copenhagen
Steve Lime,
When we worked this out years ago it was before you could rotate the map
and I think the algorithm used assume map up was north. we probably need
to make an adjustment if the map is rotated.
-Steve W
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
