[mapserver-users] Configure a images pyramid in mapserver - gdal_retile command
Erik Gustafson
gustafson.erik at gmail.com
Fri Feb 22 01:22:45 PST 2019
have you found the documentation, https://mapserver.org/input/raster.html,
specifically chapter "Raster and Tile indexing"
I can try to help if you have a more precise question.
/Erik
On Mon, Feb 18, 2019 at 3:21 AM Herbert <herbertscbr at gmail.com> wrote:
> I have already created a pyramid of images with GDAL using the command
> gdal_retile.
> I currently use the geoserver, but I want to test the performance with the
> mapserver. (The geoserver has already created the .shp and .proj files
> inside each directory of the pyramid)
> I already see it:
> https://lists.osgeo.org/pipermail/mapserver-users/2010-August/066444.html
> but i used gdal_retile and I want check for this possibility..
> thanks
> Herbert
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190222/e7e15c1a/attachment.html>
