[mapserver-users] Order of layers
Marek Bąk
rainy3 at poczta.onet.pl
Mon Feb 25 10:13:21 PST 2019
Dear All,
I'm working on project for which maps in different scales are delivered
by customer. Higher scale means more details but less coverage. Output
can have glitches but it cannot have any gaps (it should works in
similar way like in opencpn - high detailed maps shadow less detailed
but at the same moment you can enable and disable groups of layers). So
having layers like that:
LAYER (GROUP "WATER", NAME "WATERBIG", COMPOP src-over)
LAYER (GROUP "LAND", NAME "LANDBIG", COMPOP src-over)
LAYER (GROUP "TREES", NAME "TREESBIG", COMPOP src-over)
LAYER (GROUP "WATER", NAME "WATERMID", COMPOP src-over)
LAYER (GROUP "LAND", NAME "LANDMID", COMPOP src-over)
LAYER (GROUP "TREES", NAME "TREESMID", COMPOP src-over)
LAYER (GROUP "WATER", NAME "WATERSMALL", COMPOP src-over)
LAYER (GROUP "LAND", NAME "LANDSMALL", COMPOP src-over)
LAYER (GROUP "TREES", NAME "TREESSMALL", COMPOP src-over)
I'd have output in which:
MID replaces BIG within its EXTENT (completely both transparent and
non-transparent pixels)
SMALL replaces BIG and MID within its EXTENT (completely both
transparent and non-transparent pixels)
But I'm having problem to force reset some EXTENT to transparent color.
Someting like:
LAYER (GROUP "RESET", NAME "RESETMID", COMPOP ??? - what to put here to
have precalcuated EXTENT (not whole buffer) of render buffer to reset to
transparent
Is it possible to achieve with MapServer using GROUP attribute and some
kind reset extent layer?
Regards,
Marek
