[mapserver-users] probleme mapserver 5.x tutorial
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Mon Feb 25 16:00:33 PST 2019
Hi: In that particular example the states label layer should become:
LAYER # States label layer begins here
NAME states
DATA states_ugl
STATUS OFF
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASSITEM "CLASS"
LABELITEM "STATE"
CLASS
EXPRESSION 'land'
LABEL
COLOR 132 31 31
OUTLINECOLOR 128 128 128
SHADOWCOLOR 218 218 218
SHADOWSIZE 1 1
TYPE TRUETYPE
FONT arial-bold
SIZE 12
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 200
BUFFER 4
END # end of label
END # end of class
END # States label layer ends here
The reason you might want to use a label style is for something like drawing a road shield paired with a road number but that’s not necessary in this particular case. We really do need to update the demo and tutorials for 7.0 and newer versions. The changes are minor but can be frustrating for a new user. Please feel free to reach out as often as you need and I’ll do my best to help!
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bogui Yannick Dogne
Sent: Monday, February 25, 2019 10:02 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] probleme mapserver 5.x tutorial
hello I am really new on mapserver. I started learning through the tutorial but I am stuck on section 1 example 1-9 which does not appear in my browser: Annotation Layers have been removed. To obtain same functionality, use a layer with label->styles and no class->styles. this also applies to section 2 I did some research but I still do not understand how to do it.
should you change the annotation block or just add a style in label, if you have some examples and also anything that could help me learn better mapserver.
thank you so much
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190226/c56e5f26/attachment.html>
