[mapserver-users] SVG OUTPUTFORMAT TEXT LABEL
Adrian Dahinden
A.Dahinden at alpgis.ch
Wed Feb 27 02:50:50 PST 2019
Hello mapserver users
Does anyone have experience with the SVG OUTPUTFORMAT of MapServer when rendering text labels?
For a GetMap request with the format <FORMAT = image / svg + xml> the mapserver returns on text labels the labels as <path ...> instead of <text ...> svg elements.
According to the documentation, this should not be the case with TRUETYPE fonts: https://mapserver.org/output/svg.html#text-features
I assume there the docs isn't true yet, since it is over 10 years old. Or is this simply not implemented in the CAIRO/SVG render engine?
My MapFile configuration looks like this:
MAP
IMAGETYPE svg
OUTPUTFORMAT
NAME svg
MIMETYPE "image/svg+xml"
DRIVER CAIRO/SVG
FORMATOPTION "COMPRESSED_OUTPUT=FALSE"
FORMATOPTION "FULL_RESOLUTION=TRUE"
IMAGEMODE RGB
EXTENSION "svg"
END
WEB
IMAGEPATH 'geotmp/log/mapserver/'
IMAGEURL 'geotmp/log/mapserver/'
END
LAYER
NAME "Nr"
TYPE POINT
PROJECTION
"init=epsg:2056"
END
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTION "user=www-data password=www-data dbname=... host=..."
DATA "pos from (SELECT ... FROM ...) AS foo using unique gid using epsg:2056"
LABELITEM "nummer"
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 5
COLOR 0 0 0
END
END
END
END
We use MapServer version 7.0.4.
Kind regards
Adrian Dahinden
ALPGIS AG
Raumentwicklung und Geoinformation
Fliederweg 11
3600 Thun
Telefon 033 224 04 30 / direkt 033 224 04 34
Fax 033 224 40 60
www.alpgis.ch<http://www.alpgis.ch/>
mailto:a.dahinden at alpgis.ch
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190227/c835ace6/attachment.html>
