[mapserver-users] SVG OUTPUTFORMAT TEXT LABEL
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Wed Feb 27 07:33:25 PST 2019
I'm guessing that this is a CAIRO issue because mapserver hands off the
rendering to CAIRO and at a low level CAIRO is sending the vectors to
the SVG file rather than rasterizing them. That said, I haven't looked
at the code and I'll defer to any of the dev's.
-Steve W
On 2/27/2019 5:50 AM, Adrian Dahinden wrote:
> Hello mapserver users
> Does anyone have experience with the SVG OUTPUTFORMAT of MapServer
> when rendering text labels?
> For a GetMap request with the format «FORMAT = image / svg + xml» the
> mapserver returns on text labels the labels as <path ...> instead of
> <text ...> svg elements.
> According to the documentation, this should not be the case with
> TRUETYPE fonts: https://mapserver.org/output/svg.html#text-features
> I assume there the docs isn’t true yet, since it is over 10 years old.
> Or is this simply not implemented in the CAIRO/SVG render engine?
> My MapFile configuration looks like this:
> MAP
> IMAGETYPE svg
> OUTPUTFORMAT
> NAME svg
> MIMETYPE "image/svg+xml"
> DRIVER CAIRO/SVG
> FORMATOPTION "COMPRESSED_OUTPUT=FALSE"
> FORMATOPTION "FULL_RESOLUTION=TRUE"
> IMAGEMODE RGB
> EXTENSION "svg"
> END
> WEB
> IMAGEPATH 'geotmp/log/mapserver/'
> IMAGEURL 'geotmp/log/mapserver/'
> END
> LAYER
> NAME "Nr"
> TYPE POINT
> PROJECTION
> "init=epsg:2056"
> END
> CONNECTIONTYPE postgis
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CONNECTION "user=www-data password=www-data dbname=… host=…"
> DATA "pos from (SELECT … FROM …) AS foo using unique gid using
> epsg:2056"
> LABELITEM "nummer"
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 5
> COLOR 0 0 0
> END
> END
> END
> END
> We use MapServer version 7.0.4.
> Kind regards
> Adrian Dahinden
> ALPGIS AG
> Raumentwicklung und Geoinformation
> Fliederweg 11
> 3600 Thun
> Telefon 033 224 04 30 / direkt 033 224 04 34
> Fax 033 224 40 60
> www.alpgis.ch <http://www.alpgis.ch/>
> mailto:a.dahinden at alpgis.ch
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
