[mapserver-users] reserved words
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Jan 25 00:58:44 PST 2019
Hello Sebastiano,
yes:
https://mapserver.org/mapfile/template.html#file-reference
but:
the keywords only should be replaced, if you use the brackets []
and I don't know, if it is possible to escape the brackets.
Regards, Jörg
Am 25.01.19 um 09:34 schrieb Sebastiano Laini:
> Hello,
> Is there some reserved words for the xml template that you can’t use as
> a field?
> Yesterday in a XML template to have back data from the database there
> was a field called LEGEND, and that instead of giving back the column
> LEGEND from the database was populate with a linux path followed by an
> image that doesn’t exist.
> I’m using Mapserver 6 with a .map file for the data layer and it calls
> an xml template to give back the info from the database.
> Regards,
> Sebastiano Laini
> Web Developer
> Buchanan Computing
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://foss-academy.com/kompaktkurse
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
