[mapserver-users] reserved words
Sebastiano Laini
Sebastiano.Laini at BuchananComputing.co.uk
Fri Jan 25 01:47:52 PST 2019
Yes, I'm using brackets
<fstatus>[fstatus]</fstatus>
Sebastiano Laini
Web Developer
Buchanan Computing
Sent: 25 January 2019 08:34
To: 'mapserver-users at lists.osgeo.org' <mapserver-users at lists.osgeo.org>
Subject: reserved words
Hello,
Is there some reserved words for the xml template that you can't use as a field?
Yesterday in a XML template to have back data from the database there was a field called LEGEND, and that instead of giving back the column LEGEND from the database was populate with a linux path followed by an image that doesn't exist.
I'm using Mapserver 6 with a .map file for the data layer and it calls an xml template to give back the info from the database.
Regards,
Sebastiano Laini
Web Developer
Buchanan Computing
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190125/c9a7d2ac/attachment.html>
