[mapserver-users] Projection library error.
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jul 8 08:22:28 PDT 2019
Hi Ahmet,
Did you resolve this issue?
I don't use the binary that you mention, but I guess it depends on which
version of PROJ you are using, as PROJ 5.2.0 requires the file "epsg"
and PROJ 6 requires "proj.db". MapServer 7.4.0 should be able to find
either one.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-07-07 11:25 AM, Ahmet Temiz wrote:
> after I install mapserver binary version in ubuntu 19,
> I received proj related error message.
> shp2img
> msProcessProjection(): Projection library error. proj error "no
> arguments in initialization list" for "init=epsg:3857"
> here is the related code fragment:
> CONFIG "PROJ_LIB" "/usr/share/"
> CONFIG "MS_ERRORFILE" "/var/www/ms_map/ms_error.log"
> PROJECTION
> "init=epsg:3857"
> END
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
> __
More information about the MapServer-users
