[mapserver-users] Projection library error.
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Jul 9 11:35:23 PDT 2019
Hi Ahmet,
As luck would have it, I just now hit your exact same issue, same error
message ("no arguments in initialization list").  In my case, this was
due to a mapfile pointing to the wrong location of the epsg file through:
    CONFIG "PROJ_LIB" "C:/bad/path"
So be sure to point to the correct location, for your binary.  (as I
mentioned earlier, it may depend on what PROJ version you have)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-07-07 11:25 AM, Ahmet Temiz wrote:
> after I install mapserver binary version in ubuntu 19,
> I received proj related error message.
> shp2img
> msProcessProjection(): Projection library error. proj error "no
> arguments in initialization list" for "init=epsg:3857"
> here is the related code fragment:
>      CONFIG "PROJ_LIB" "/usr/share/"
>      CONFIG "MS_ERRORFILE" "/var/www/ms_map/ms_error.log"
>    PROJECTION
>       "init=epsg:3857"
>    END
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
More information about the MapServer-users mailing list
