[mapserver-users] WFS GeoJSON Output Missing numberMatched
Seth G sethg at geographika.co.uk
Wed Jun 5 15:39:03 PDT 2019
Thanks Even for both suggestions.
Using resultType=hits and caching the result for the duration of the session could be an option for read-only layers (and would likely speed things up as setting  "wfs_compute_number_matched" is not recommended for performance reasons). Editable layers would require two requests on every request, which might be ok depending on speeds.
The second approach is probably more robust, and works fine in a Mapfile by setting these layer creation options (although obviously the numberMatched in hard-coded):
    OUTPUTFORMAT
        NAME "application/json"
        DRIVER "OGR/GEOJSON"
        MIMETYPE "application/json"
        FORMATOPTION "FORM=SIMPLE"
        FORMATOPTION "STORAGE=memory" # filesystem and memory both work (only use one)
        FORMATOPTION "LCO:NATIVE_MEDIA_TYPE=application/vnd.geo+json"
        FORMATOPTION "LCO:NATIVE_DATA={'numberMatched':6607}"
    END
It looks like mapogroutput.c would need to be modified to support this approach.
Thanks again for the options,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, Jun 6, 2019, at 12:06 AM, Even Rouault wrote:
> On mercredi 5 juin 2019 23:43:22 CEST Seth G wrote:
> > Hi all,
> > I'm currently working on a front-end grid that requests features via WFS 2.0
> > and loads them using OpenLayers. OpenLayers 4 doesn't support parsing of
> > GML3 used by WFS 2.0, but I can return features as GeoJSON by setting the
> > output format as follows:
> >     OUTPUTFORMAT
> >         NAME "geojson"
> >         MIMETYPE "application/json; subtype=geojson"
> >     END
> > Then setting WEB > METADATA > "wfs_getfeature_formatlist"
> > "gml,geojson,application/json"
> > WFS requests  are then made with URL parameters such as
> > &service=WFS&version=2.0.0&request=GetFeature&typeName=MyLayer&outputFormat
> > =application%2Fjson&startIndex=0&count=20
> > Everything works fine including paging, but in order to calculate how many
> > "pages" of data I need to get the numberMatched property. This can be
> > turned on for GML3 using WEB > METADATA > "wfs_compute_number_matched"
> > "true" (as noted at
> > https://mapserver.org/fr/ogc/wfs_server.html#web-object-metadata).
> > If I then request GML with outputFormat=gml3 the GML response includes
> > numberMatched="6607" (the number of features in the layer).
> > As GML3 features can't be rendered in OpenLayers I'd like to get this
> > property added to the GeoJSON output. This appears to be implemented in
> > GeoServer. I was wondering if this is something that can be configured
> > somewhere in the Mapfile perhaps as an option for the OGR/GEOJSON driver
> > (https://gdal.org/drivers/vector/geojson.html). The timeStamp,
> > numberReturned are also missing from the GeoJSON output.
> > Any ideas or hints appreciated,
> If your need is just to compute the number of patches, to get the
> numberMatched, you could issue a GetFeature request with resultType=hits and
> the default GML3 outputFormat. But I guess that's not an option given your
> architecture.
> If you absolutely need that in the GeoJSON output itself, you'll need to add
> that specific behaviour in MapServer.
> If you provide the NATIVE_MEDIA_TYPE=application/vnd.geo+json and
> NATIVE_DATA={"numberMatched":XXXX} layer creation options to
> OGR_DS_CreateLayer(), the OGR GeoJSON driver should include them in the output
> (with a recent enough GDAL version)
> $ ogr2ogr -f geojson /vsistdout/ poly.shp \
>    -lco NATIVE_MEDIA_TYPE=application/vnd.geo+json \
>    -lco 'NATIVE_DATA={"numberMatched":1234}'
> "type": "FeatureCollection",
> "numberMatched": 1234,
> "name": "poly",
> "features": [
> [snip]
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the MapServer-users mailing list
