[mapserver-users] WFS GeoJSON Output Missing numberMatched
Julian Hollingbery
julian at northtech.dk
Fri Jun 7 05:34:56 PDT 2019
Maybe this is a stupid idea, but could you not simply keep asking until you get a page with zero features?
Regards,
Julian
-----Oprindelig meddelelse-----
Date: Wed, 05 Jun 2019 23:43:22 +0200
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WFS GeoJSON Output Missing numberMatched
Message-ID: <c7639659-93ff-41bf-bb30-ae4c3848a2ac at www.fastmail.com>
Content-Type: text/plain
Hi all,
I'm currently working on a front-end grid that requests features via WFS 2.0 and loads them using OpenLayers.
OpenLayers 4 doesn't support parsing of GML3 used by WFS 2.0, but I can return features as GeoJSON by setting the output format as follows:
OUTPUTFORMAT
NAME "geojson"
DRIVER "OGR/GEOJSON"
MIMETYPE "application/json; subtype=geojson"
FORMATOPTION "FORM=SIMPLE"
FORMATOPTION "STORAGE=memory"
END
Then setting WEB > METADATA > "wfs_getfeature_formatlist" "gml,geojson,application/json"
WFS requests are then made with URL parameters such as &service=WFS&version=2.0.0&request=GetFeature&typeName=MyLayer&outputFormat=application%2Fjson&startIndex=0&count=20
Everything works fine including paging, but in order to calculate how many "pages" of data I need to get the numberMatched property.
This can be turned on for GML3 using WEB > METADATA > "wfs_compute_number_matched" "true" (as noted at https://mapserver.org/fr/ogc/wfs_server.html#web-object-metadata).
If I then request GML with outputFormat=gml3 the GML response includes numberMatched="6607" (the number of features in the layer).
As GML3 features can't be rendered in OpenLayers I'd like to get this property added to the GeoJSON output. This appears to be implemented in GeoServer.
I was wondering if this is something that can be configured somewhere in the Mapfile perhaps as an option for the OGR/GEOJSON driver (https://gdal.org/drivers/vector/geojson.html).
The timeStamp, numberReturned are also missing from the GeoJSON output.
Any ideas or hints appreciated,
Seth
web:http://geographika.co.uk
twitter: @geographika
Message: 3
Date: Thu, 06 Jun 2019 00:39:03 +0200
To: "Even Rouault" <even.rouault at spatialys.com>,
Subject: Re: [mapserver-users] WFS GeoJSON Output Missing
numberMatched
Message-ID: <0a5df404-ffc4-431e-a520-80b8822525dd at www.fastmail.com>
Thanks Even for both suggestions.
Using resultType=hits and caching the result for the duration of the session could be an option for read-only layers (and would likely speed things up as setting "wfs_compute_number_matched" is not recommended for performance reasons). Editable layers would require two requests on every request, which might be ok depending on speeds.
The second approach is probably more robust, and works fine in a Mapfile by setting these layer creation options (although obviously the numberMatched in hard-coded):
OUTPUTFORMAT
NAME "application/json"
MIMETYPE "application/json"
FORMATOPTION "STORAGE=memory" # filesystem and memory both work (only use one)
FORMATOPTION "LCO:NATIVE_MEDIA_TYPE=application/vnd.geo+json"
FORMATOPTION "LCO:NATIVE_DATA={'numberMatched':6607}"
END
It looks like mapogroutput.c would need to be modified to support this approach.
Thanks again for the options,
Seth
More information about the MapServer-users
