[mapserver-users] Error While Generating Tiles
Yves Jacolin
yves.jacolin at camptocamp.com
Wed Mar 6 06:19:01 PST 2019
Did you improve Postgresql configuration (shared_buffer and work_mem
parameters) ?
Y.
Le mer. 6 mars 2019 à 15:15, parsis presswala <parsispresswala at gmail.com> a
écrit :
> Hello,
> I have already created indexing on some fields. Here is my indexed fields.
> CREATE INDEX planet_osm_polygon_idx
> ON public.planet_osm_polygon
> USING btree
> (waterway COLLATE pg_catalog."default", "natural" COLLATE
> pg_catalog."default", landuse COLLATE pg_catalog."default", building
> COLLATE pg_catalog."default", aeroway COLLATE pg_catalog."default", leisure
> COLLATE pg_catalog."default", amenity COLLATE pg_catalog."default");
> Even I have experiment with r4.8xlarge with 32 CPU and 244 GB RAM. But
> got same result.
> What should I do?
> On Wed, Mar 6, 2019 at 7:31 PM Yves Jacolin <yves.jacolin at camptocamp.com>
> wrote:
>> You probablty needs to create index(es) on leisure, landuse and amenity.
>> Probably both of all but you need to do some test.
>> Second, you probably needs to improve PostgreSQL configuration to let
>> PostgreSQL use your 61 GB of RAM :) shared_buffers and work_mem are good
>> parameters to look for.
>> Y.
>> Le mer. 6 mars 2019 à 14:56, parsis presswala <parsispresswala at gmail.com>
>> a écrit :
>>> Hello,
>>> Yes I am using OSM data.
>>> I have imported it using osm2pgsql. Database: asiadb and tables
>>> are planet_osm_line, planet_osm_point, planet_osm_polygon, planet_osm_roads.
>>> I have imported data of whole planet using 40 GB .osm.pbf file.
>>> First I have only imported data of Asia and created map using
>>> map-server, which is working fine but as soon as import data of whole
>>> world, this problem occurred.
>>> I have 61 GB RAM and 8 Core processor as i am working on Amazon Elastic
>>> Compute Cloud (Amazon EC2) type r4.2xlarge.
>>> Here is my mapfile.
>>> http://13.126.201.198/asiamap.map
>>> I have run EXPLAIN <slow request> and got following result:
>>> "Seq Scan on planet_osm_polygon (cost=0.00..18878787.88 rows=36617920
>>> width=277)"
>>> " Filter: ((leisure IS NOT NULL) OR (landuse IS NOT NULL) OR (amenity
>>> IS NOT NULL))"
>>> On Wed, Mar 6, 2019 at 7:04 PM Yves Jacolin <yves.jacolin at camptocamp.com>
>>> wrote:
>>>> Some questions that can help you :)
>>>> is it OSM data? How do you import them?
>>>> What is the extent of the data? Could you check if spatial indexes
>>>> exist? Could you run EXPLAIN <your slow request> and analyze it?
>>>> Y.
>>>> Le mer. 6 mars 2019 à 14:29, parsis presswala <
>>>> parsispresswala at gmail.com> a écrit :
>>>>> Hello,
>>>>> Here is a log of PostgreSQL. I consider that PostgreSQL takes very
>>>>> long time to execute query on polygon. What should I do fot it?
>>>>> 2019-03-06 11:23:49.620 UTC [2302] parsis at asiadb STATEMENT: select
>>>>> "highway"::text,"name"::text,"reflen"::text,"ref"::text,ST_AsBinary(ST_Force2D("way"),'NDR')
>>>>> as geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way,
>>>>> highway, name, ref, oneway, CHAR_LENGTH(ref) AS reflen FROM planet_osm_line
>>>>> WHERE highway IN ('motorway', 'trunk','motorway_link','trunk_link') AND
>>>>> (name IS NOT NULL OR ref IS NOT NULL)) AS data) as nullidq where "way" &&
>>>>> ST_GeomFromText('POLYGON((-9473834.25396072
>>>>> 2853929.66787328,-9473834.25396072 3446928.13330971,-8880835.78852428
>>>>> 3446928.13330971,-8880835.78852428 2853929.66787328,-9473834.25396072
>>>>> 2853929.66787328))',900913)
>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb LOG: could not send
>>>>> data to client: Broken pipe
>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb STATEMENT: select
>>>>> "stylegroup"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>> geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way, CASE
>>>>> WHEN leisure in
>>>>> ('park','garden','playground','golf_course','sports_centre','pitch','stadium','nature_reserve','common')
>>>>> THEN 'leisuree' WHEN landuse
>>>>> IN('park','forest','grass','farmyard','farm','farmland','wood','meadow','village_green','recreation_ground')
>>>>> THEN 'landusee' WHEN amenity in
>>>>> ('university','school','college','library','fuel','parking','cinema','theatre','place_of_worship','hospital')
>>>>> THEN 'amenityy' END AS stylegroup FROM planet_osm_polygon where (leisure is
>>>>> not null) or (landuse is not null) or (amenity is not null)) AS data) as
>>>>> nullidq where "way" && ST_GeomFromText('POLYGON((8116389.75422228
>>>>> -1276192.28146022,8116389.75422228 3467795.44203122,12860377.4777137
>>>>> 3467795.44203122,12860377.4777137 -1276192.28146022,8116389.75422228
>>>>> -1276192.28146022))',900913)
>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb LOG: could not send
>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb STATEMENT: select
>>>>> WHEN leisure in
>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb FATAL: connection
>>>>> to client lost
>>>>> 2019-03-06 12:08:25.564 UTC [3362] parsis at asiadb STATEMENT: select
>>>>> ST_AsBinary(ST_Force2D("way"),'NDR') as geom,"nullid"::text from (select *,
>>>>> NULL as nullid from ( SELECT way FROM planet_osm_polygon WHERE (waterway IN
>>>>> ('riverbank')) OR ("natural" IN ('water')) OR (landuse IN ('basin',
>>>>> 'reservoir')) ) AS data) as nullidq where "way" &&
>>>>> ST_GeomFromText('POLYGON((-20228294.8225998
>>>>> -20228294.8225998,-20228294.8225998 17723606.9653297,17723606.9653297
>>>>> 17723606.9653297,17723606.9653297 -20228294.8225998,-20228294.8225998
>>>>> -20228294.8225998))',900913)
>>>>> 2019-03-06 12:08:25.564 UTC [3260] FATAL: terminating connection due
>>>>> to administrator command
>>>>> 2019-03-06 12:08:25.564 UTC [3260] STATEMENT: select
>>>>> 2019-03-06 12:08:25.564 UTC [3261] FATAL: terminating connection due
>>>>> 2019-03-06 12:08:25.564 UTC [3261] STATEMENT: select
>>>>> 2019-03-06 12:08:25.564 UTC [3363] FATAL: terminating connection due
>>>>> 2019-03-06 12:08:25.564 UTC [3363] STATEMENT: select
>>>>> 2019-03-06 12:08:25.570 UTC [1535] LOG: worker process: parallel
>>>>> worker for PID 3255 (PID 3261) exited with exit code 1
>>>>> worker for PID 3362 (PID 3363) exited with exit code 1
>>>>> worker for PID 3255 (PID 3260) exited with exit code 1
>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb LOG: could not send
>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb STATEMENT: select
>>>>> "admin_level"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>> geom,"nullid"::text from (select *, NULL as nullid from (select * from
>>>>> planet_osm_line where admin_level IN('2') and boundary IN
>>>>> ('administrative') and way NOT IN (SELECT way FROM planet_osm_line where
>>>>> admin_level IN('2') and boundary like 'administrative' and (tags->'dispute'
>>>>> = 'yes' or tags->'ISO3166-1' IN ('IN','CN','PK') or way IN(select way from
>>>>> in_cn_ignored_border)))) AS data) as nullidq where "way" &&
>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb FATAL: connection
>>>>> to client lost
>>>>> Regards,
>>>>> Parsis Presswala
>>>>> On Wed, Mar 6, 2019 at 6:35 PM Yves Jacolin <
>>>>> yves.jacolin at camptocamp.com> wrote:
>>>>>> Hello,
>>>>>> Did you try to curl the request and see what happens: timeout, etc.
>>>>>> If so, try to get some log (mapserver or postgresql log) and see where is
>>>>>> the bottleneck.
>>>>>> Y.
>>>>>> Le mer. 6 mars 2019 à 13:58, parsis presswala <
>>>>>>> Hello,
>>>>>>> I am getting following error while generating tiles. I can't get the
>>>>>>> reason of this error. I an using mapcache to generate tiles.
>>>>>>> failed to seed tile z10,x645,y510:
>>>>>>> curl failed to request url
>>>>>>> http://13.126.201.198/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=5201998.739765%2c-81328.655306%2c5795150.079258%2c511822.684187&WIDTH=3880&HEIGHT=3880&FORMAT=image%2fpng&SRS=EPSG%3a3857&LAYERS=osm_new_admin%2cosm_new_adminocean%2cosm_new_landusages%2cosm_new_water%2cbuildings%2caeroway%2cosm_new_waterways%2cosm_new_railways%2cplanet_osm_roads%2cplanet_osm_roads_line%2cosm_new_railways1%2ccountry_line%2ccountry_line_claim%2cstate_line%2cmotorway_label%2cmainroad_label%2cminorroad_label%2cosm_new_railways_symbol%2cplace-country%2cplace-state%2cplace-city%2cplace-town%2cplace-Suburb%2cplace-village%2cplace-locality%2carea_label%2caerodrome_label%2cwaterway_label%2cwaterarea_label%2cpoi_pointlabel&MAP=%2fhome%2fubuntu%2fworldmap%2fasiamap.map
>>>>>>> : Operation timed out after 600000 milliseconds with 0 bytes received
>>>>>>> aborting seed as 100.0% of the last 1000 requests failed
>>>>>>> seeded 225 tiles, now at z10 x660 y510
>>>>>>> seeded 2 metatiles (450 total tiles, 450 non-empty tiles) in 1201.8
>>>>>>> seconds at 0.4 tiles/sec (0.4 non-empty tiles/sec)
>>>>>>> If anyone could help me with this, it would be greatly appreciated.
>>>>>>> Regards,
>>>>>>> Parsis Presswala
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>> Yves Jacolin
>>>>>> Training and support manager - Team Manager
>>>>>> Camptocamp
>>>>>> Tel (France) : +33 4 58 48 20 43
>>>>>> Tel (Switzerland) : +41 21 619 10 43
>>>>>> Mob. : +33 6 18 75 42 21
>>>>>> email : yves.jacolin at camptocamp.com
>>>>>> http://www.camptocamp.com
>>>> Yves Jacolin
>>>> Camptocamp
>> Yves Jacolin
>> Camptocamp
Yves Jacolin
Camptocamp
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190306/d01db3ce/attachment-0001.html>
