[mapserver-users] Error While Generating Tiles
parsis presswala
parsispresswala at gmail.com
Wed Mar 6 06:31:52 PST 2019
I have improve Postgresql configuration shared_buffer = 20000 MB and
work_mem = 500 MB.
Is this configuration fine or I need to improve more?
On Wed, Mar 6, 2019 at 7:53 PM parsis presswala <parsispresswala at gmail.com>
wrote:
> No, not yet.
> On Wed, Mar 6, 2019 at 7:49 PM Yves Jacolin <yves.jacolin at camptocamp.com>
> wrote:
>> Did you improve Postgresql configuration (shared_buffer and work_mem
>> parameters) ?
>> Y.
>> Le mer. 6 mars 2019 à 15:15, parsis presswala <parsispresswala at gmail.com>
>> a écrit :
>>> Hello,
>>> I have already created indexing on some fields. Here is my indexed
>>> fields.
>>> CREATE INDEX planet_osm_polygon_idx
>>> ON public.planet_osm_polygon
>>> USING btree
>>> (waterway COLLATE pg_catalog."default", "natural" COLLATE
>>> pg_catalog."default", landuse COLLATE pg_catalog."default", building
>>> COLLATE pg_catalog."default", aeroway COLLATE pg_catalog."default", leisure
>>> COLLATE pg_catalog."default", amenity COLLATE pg_catalog."default");
>>> Even I have experiment with r4.8xlarge with 32 CPU and 244 GB RAM. But
>>> got same result.
>>> What should I do?
>>> On Wed, Mar 6, 2019 at 7:31 PM Yves Jacolin <yves.jacolin at camptocamp.com>
>>> wrote:
>>>> You probablty needs to create index(es) on leisure, landuse and
>>>> amenity. Probably both of all but you need to do some test.
>>>> Second, you probably needs to improve PostgreSQL configuration to let
>>>> PostgreSQL use your 61 GB of RAM :) shared_buffers and work_mem are good
>>>> parameters to look for.
>>>> Y.
>>>> Le mer. 6 mars 2019 à 14:56, parsis presswala <
>>>> parsispresswala at gmail.com> a écrit :
>>>>> Hello,
>>>>> Yes I am using OSM data.
>>>>> I have imported it using osm2pgsql. Database: asiadb and tables
>>>>> are planet_osm_line, planet_osm_point, planet_osm_polygon, planet_osm_roads.
>>>>> I have imported data of whole planet using 40 GB .osm.pbf file.
>>>>> First I have only imported data of Asia and created map using
>>>>> map-server, which is working fine but as soon as import data of whole
>>>>> world, this problem occurred.
>>>>> I have 61 GB RAM and 8 Core processor as i am working on Amazon
>>>>> Elastic Compute Cloud (Amazon EC2) type r4.2xlarge.
>>>>> Here is my mapfile.
>>>>> http://13.126.201.198/asiamap.map
>>>>> I have run EXPLAIN <slow request> and got following result:
>>>>> "Seq Scan on planet_osm_polygon (cost=0.00..18878787.88 rows=36617920
>>>>> width=277)"
>>>>> " Filter: ((leisure IS NOT NULL) OR (landuse IS NOT NULL) OR (amenity
>>>>> IS NOT NULL))"
>>>>> On Wed, Mar 6, 2019 at 7:04 PM Yves Jacolin <
>>>>> yves.jacolin at camptocamp.com> wrote:
>>>>>> Some questions that can help you :)
>>>>>> is it OSM data? How do you import them?
>>>>>> What is the extent of the data? Could you check if spatial indexes
>>>>>> exist? Could you run EXPLAIN <your slow request> and analyze it?
>>>>>> Y.
>>>>>> Le mer. 6 mars 2019 à 14:29, parsis presswala <
>>>>>>> Hello,
>>>>>>> Here is a log of PostgreSQL. I consider that PostgreSQL takes very
>>>>>>> long time to execute query on polygon. What should I do fot it?
>>>>>>> 2019-03-06 11:23:49.620 UTC [2302] parsis at asiadb STATEMENT: select
>>>>>>> "highway"::text,"name"::text,"reflen"::text,"ref"::text,ST_AsBinary(ST_Force2D("way"),'NDR')
>>>>>>> as geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way,
>>>>>>> highway, name, ref, oneway, CHAR_LENGTH(ref) AS reflen FROM planet_osm_line
>>>>>>> WHERE highway IN ('motorway', 'trunk','motorway_link','trunk_link') AND
>>>>>>> (name IS NOT NULL OR ref IS NOT NULL)) AS data) as nullidq where "way" &&
>>>>>>> ST_GeomFromText('POLYGON((-9473834.25396072
>>>>>>> 2853929.66787328,-9473834.25396072 3446928.13330971,-8880835.78852428
>>>>>>> 3446928.13330971,-8880835.78852428 2853929.66787328,-9473834.25396072
>>>>>>> 2853929.66787328))',900913)
>>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb LOG: could not
>>>>>>> send data to client: Broken pipe
>>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb STATEMENT: select
>>>>>>> "stylegroup"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>>>> geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way, CASE
>>>>>>> WHEN leisure in
>>>>>>> ('park','garden','playground','golf_course','sports_centre','pitch','stadium','nature_reserve','common')
>>>>>>> THEN 'leisuree' WHEN landuse
>>>>>>> IN('park','forest','grass','farmyard','farm','farmland','wood','meadow','village_green','recreation_ground')
>>>>>>> THEN 'landusee' WHEN amenity in
>>>>>>> ('university','school','college','library','fuel','parking','cinema','theatre','place_of_worship','hospital')
>>>>>>> THEN 'amenityy' END AS stylegroup FROM planet_osm_polygon where (leisure is
>>>>>>> not null) or (landuse is not null) or (amenity is not null)) AS data) as
>>>>>>> nullidq where "way" && ST_GeomFromText('POLYGON((8116389.75422228
>>>>>>> -1276192.28146022,8116389.75422228 3467795.44203122,12860377.4777137
>>>>>>> 3467795.44203122,12860377.4777137 -1276192.28146022,8116389.75422228
>>>>>>> -1276192.28146022))',900913)
>>>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb LOG: could not
>>>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb STATEMENT: select
>>>>>>> WHEN leisure in
>>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb FATAL: connection
>>>>>>> to client lost
>>>>>>> 2019-03-06 12:08:25.564 UTC [3362] parsis at asiadb STATEMENT: select
>>>>>>> ST_AsBinary(ST_Force2D("way"),'NDR') as geom,"nullid"::text from (select *,
>>>>>>> NULL as nullid from ( SELECT way FROM planet_osm_polygon WHERE (waterway IN
>>>>>>> ('riverbank')) OR ("natural" IN ('water')) OR (landuse IN ('basin',
>>>>>>> 'reservoir')) ) AS data) as nullidq where "way" &&
>>>>>>> ST_GeomFromText('POLYGON((-20228294.8225998
>>>>>>> -20228294.8225998,-20228294.8225998 17723606.9653297,17723606.9653297
>>>>>>> 17723606.9653297,17723606.9653297 -20228294.8225998,-20228294.8225998
>>>>>>> -20228294.8225998))',900913)
>>>>>>> 2019-03-06 12:08:25.564 UTC [3260] FATAL: terminating connection
>>>>>>> due to administrator command
>>>>>>> 2019-03-06 12:08:25.564 UTC [3260] STATEMENT: select
>>>>>>> 2019-03-06 12:08:25.564 UTC [3261] FATAL: terminating connection
>>>>>>> 2019-03-06 12:08:25.564 UTC [3261] STATEMENT: select
>>>>>>> 2019-03-06 12:08:25.564 UTC [3363] FATAL: terminating connection
>>>>>>> 2019-03-06 12:08:25.564 UTC [3363] STATEMENT: select
>>>>>>> 2019-03-06 12:08:25.570 UTC [1535] LOG: worker process: parallel
>>>>>>> worker for PID 3255 (PID 3261) exited with exit code 1
>>>>>>> worker for PID 3362 (PID 3363) exited with exit code 1
>>>>>>> worker for PID 3255 (PID 3260) exited with exit code 1
>>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb LOG: could not
>>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb STATEMENT: select
>>>>>>> "admin_level"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>>>> geom,"nullid"::text from (select *, NULL as nullid from (select * from
>>>>>>> planet_osm_line where admin_level IN('2') and boundary IN
>>>>>>> ('administrative') and way NOT IN (SELECT way FROM planet_osm_line where
>>>>>>> admin_level IN('2') and boundary like 'administrative' and (tags->'dispute'
>>>>>>> = 'yes' or tags->'ISO3166-1' IN ('IN','CN','PK') or way IN(select way from
>>>>>>> in_cn_ignored_border)))) AS data) as nullidq where "way" &&
>>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb FATAL: connection
>>>>>>> to client lost
>>>>>>> Regards,
>>>>>>> Parsis Presswala
>>>>>>> On Wed, Mar 6, 2019 at 6:35 PM Yves Jacolin <
>>>>>>>> Hello,
>>>>>>>> Did you try to curl the request and see what happens: timeout, etc.
>>>>>>>> If so, try to get some log (mapserver or postgresql log) and see where is
>>>>>>>> the bottleneck.
>>>>>>>> Y.
>>>>>>>> Le mer. 6 mars 2019 à 13:58, parsis presswala <
>>>>>>>>> Hello,
>>>>>>>>> I am getting following error while generating tiles. I can't get
>>>>>>>>> the reason of this error. I an using mapcache to generate tiles.
>>>>>>>>> failed to seed tile z10,x645,y510:
>>>>>>>>> curl failed to request url
>>>>>>>>> http://13.126.201.198/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=5201998.739765%2c-81328.655306%2c5795150.079258%2c511822.684187&WIDTH=3880&HEIGHT=3880&FORMAT=image%2fpng&SRS=EPSG%3a3857&LAYERS=osm_new_admin%2cosm_new_adminocean%2cosm_new_landusages%2cosm_new_water%2cbuildings%2caeroway%2cosm_new_waterways%2cosm_new_railways%2cplanet_osm_roads%2cplanet_osm_roads_line%2cosm_new_railways1%2ccountry_line%2ccountry_line_claim%2cstate_line%2cmotorway_label%2cmainroad_label%2cminorroad_label%2cosm_new_railways_symbol%2cplace-country%2cplace-state%2cplace-city%2cplace-town%2cplace-Suburb%2cplace-village%2cplace-locality%2carea_label%2caerodrome_label%2cwaterway_label%2cwaterarea_label%2cpoi_pointlabel&MAP=%2fhome%2fubuntu%2fworldmap%2fasiamap.map
>>>>>>>>> : Operation timed out after 600000 milliseconds with 0 bytes received
>>>>>>>>> aborting seed as 100.0% of the last 1000 requests failed
>>>>>>>>> seeded 225 tiles, now at z10 x660 y510
>>>>>>>>> seeded 2 metatiles (450 total tiles, 450 non-empty tiles) in
>>>>>>>>> 1201.8 seconds at 0.4 tiles/sec (0.4 non-empty tiles/sec)
>>>>>>>>> If anyone could help me with this, it would be greatly appreciated.
>>>>>>>>> Regards,
>>>>>>>>> Parsis Presswala
>>>>>>>>> _______________________________________________
>>>>>>>>> mapserver-users mailing list
>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>>>> Yves Jacolin
>>>>>>>> Training and support manager - Team Manager
>>>>>>>> Camptocamp
>>>>>>>> Tel (France) : +33 4 58 48 20 43
>>>>>>>> Tel (Switzerland) : +41 21 619 10 43
>>>>>>>> Mob. : +33 6 18 75 42 21
>>>>>>>> email : yves.jacolin at camptocamp.com
>>>>>>>> http://www.camptocamp.com
>>>>>> Yves Jacolin
>>>>>> Camptocamp
>>>> Yves Jacolin
>>>> Camptocamp
>> Yves Jacolin
>> Camptocamp
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190306/d19876c0/attachment-0001.html>
