[mapserver-users] How to make label background transparent?
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Fri Mar 8 19:07:09 PST 2019
I found that I can set the color -1 -1 -1 to make the color transparent,
but this does not seem to overwrite the existing colors already drawn in
the image. I suspect that the drawing in white is allocating a 2nd color
white in the color table where only the first one is being set to
transparent. I would be nice if we had a way to specify that the color
being written should be the background color and therefore will be
transparent.
So adding this to the label:
STYLE
GEOMTRANSFORM 'labelpoly'
COLOR -1 -1 -1
END
basically does nothing. IE: the labelpoly is not written at all.
-Steve W
On 3/8/2019 9:16 PM, Stephen Woodbridge wrote:
> Hi All,
> I have a mapfile with:
> MAP IMAGECOLOR 255 255 255
> and LAYER with:
> CLASS
> STYLE
> COLOR "#000000"
> WIDTH 1
> END
> LABEL
> STYLE
> COLOR 255 255 255
> END
> TEXT (tostring([DEG_F], "%.1f"))
> TYPE TRUETYPE
> FONT "arial"
> SIZE 10
> COLOR '#000000'
> #OUTLINECOLOR '#ffffff'
> #OUTLINEWIDTH 5
> MINDISTANCE 250
> MAXSCALEDENOM 1000000
> BUFFER 5
> REPEATDISTANCE 250
> PARTIALS FALSE
> END
> END
> The mapfile is for contour lines and I want to label them and break
> the contour line by setting the labelploy to the MAP IMAGECOLOR so it
> becomes transparent. Only the above is making the label poly white and
> not transparent :(
> How can I do this?
> -Steve W
> MapServer version 7.0.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
