[mapserver-users] MapCache clusters
Travis Kirstine
traviskirstine at gmail.com
Tue Nov 19 08:11:11 PST 2019
I don't think multiple instances of MapCache will help for seeding, in
general most of the seeding time depends on the zoom level, with each
higher zoom level taking 4 x the time as the proceeding zoom level (e.g.
zoom 20 take 4 x the time to seed as zoom 19) . This can vary depending
on your source service as there may be certain map scales / zoom levels
that take longer per tile to render due to expression, labels, # of
features etc... If you were to seed two levels for each mapcache instance
you still would be waiting for the higher zoom levels to complete. Using
multiple load balanced mapserver nodes across multiple VM may improve
things a bit however if all the VMs are hosted on the same physical server
this may be slower overall. For seeding I have heard you can use 2x the
number of cores so you could set up a single mapcache server using -n 16
pointing at the load balanced source.
Regards
On Mon, 18 Nov 2019 at 10:47, Sebastiano Laini <
Sebastiano.Laini at buchanancomputing.co.uk> wrote:
> Hi All,
> I was wondering if is possible to dockerise my server and then use
> multiple cluster to seed the cache? I know I can use multiple processes
> with the –n and –p flag though I’m wondering there is a limit on how much
> you can really increase those number.
> E.g. I dockerise the server and I spawn a 8core VM with 16GB ram, I can
> use sure –p 8 or maybe 10 but still I think that will require like 60 days
> to seed the whole UK with our data, can I spawn another machine and speed
> up the process? For example another 8core VM.
> We have 4 caches with different style that are updated twice a year so if
> it takes me 60 days for each by the time I finish it’s already time to
> start again.
> I was wondering maybe I can run multiple VM and seed one or maybe 2 levels
> on each VM or if I spawn a new VM the original process will take advantage
> of the new VM?
> In a VM I’m going to have MapServer and MapCache and I will use a
> subdomain under a load balancer just to seed while the domain will be use
> just for the seeded cache and in the same way will be under a load balancer.
> Regards,
> Sebastiano Laini
> Web Developer
> Buchanan Computing
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191119/ee237541/attachment.html>
