[mapserver-users] wms servers html template output
Lime, Steve D (MNIT) steve.lime at state.mn.us
Wed Oct 16 09:57:21 PDT 2019
Hi Travis: I don’t think there is an “easy” way. I mean you could script template creation so that process does the tedious work for you by looking at the map. You would create a new-style template (see RFC 36) so everything is in one file and then you’d create a single output format reference to that table.
If we wanted to support this via MapServer templates I think we’d need to do 3 things:
·         Extend the [resultset] tag to support “layer_pattern” attribute so that it (a regex) could apply to multiple layers (like any/all of them).
·         Enhance the [items] and [values] tags to control formatting. Currently those just slam the column names and values together in a delimited string.
·         Enhance the [values] tag processing to allow referencing the associated item/column name in the context of formatting.
I’d probably also propose compliance with the item-related metadata that is typically used with OGC service outputs to control which items are output…
With those changes you could write a template like so:
// MapServer Template
[resultset layer_pattern="."]
[feature]
<table>
[values format=”<tr><td>$item</td><td>$value</td></tr>]
</table>
[/feature]
[resultset]
This would give you an item/value table for any feature for any layer. You could also to more horizontal tables using the [items] tag to output one header row…
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Travis Kirstine
Sent: Tuesday, October 15, 2019 9:06 AM
To: mapserver-users <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] wms servers html template output
This message may be from an external email source.
Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
Hi all,
I'm struggling a bit with using a generic template for html getfeatureinfo requests.  Is there a easy way to create a simple html table containing the attribute field names and values for any layer.  I don't want to create a separate template for each layer.  Thanks
There was some mention of this here:
http://osgeo-org.1560.x6.nabble.com/Generic-template-for-WMS-GetFeatureInfo-td4227865.html<https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fosgeo-org.1560.x6.nabble.com%2FGeneric-template-for-WMS-GetFeatureInfo-td4227865.html&data=02%7C01%7Csteve.lime%40state.mn.us%7Caa1eb890540341ecbbab08d75178d454%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C637067451709877574&sdata=Dl5OEEEfUDw9q020aW453wCbHjNt9pOSMYDzQrW5QXo%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191016/f42ce689/attachment.htm>
More information about the MapServer-users mailing list
