[mapserver-users] wms servers html template output
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Wed Oct 16 10:44:52 PDT 2019
Travis,
We went with a slightly more involved route of caching things locally in a Postgres database. You can automate things to a certain extent with a REST service for example with some clevering automation scripting for example. We had to figure out things like how to handle when attributes changed, etc, but it was doable from a REST service.
bobb
On Oct 16, 2019, at 11:57 AM, Lime, Steve D (MNIT) <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>> wrote:
Think Before You Click: This email originated outside our organization.
Hi Travis: I don’t think there is an “easy” way. I mean you could script template creation so that process does the tedious work for you by looking at the map. You would create a new-style template (see RFC 36) so everything is in one file and then you’d create a single output format reference to that table.
If we wanted to support this via MapServer templates I think we’d need to do 3 things:
• Extend the [resultset] tag to support “layer_pattern” attribute so that it (a regex) could apply to multiple layers (like any/all of them).
• Enhance the [items] and [values] tags to control formatting. Currently those just slam the column names and values together in a delimited string.
• Enhance the [values] tag processing to allow referencing the associated item/column name in the context of formatting.
I’d probably also propose compliance with the item-related metadata that is typically used with OGC service outputs to control which items are output…
With those changes you could write a template like so:
// MapServer Template
[resultset layer_pattern="."]
[feature]
<table>
[values format=”<tr><td>$item</td><td>$value</td></tr>]
</table>
[/feature]
[resultset]
This would give you an item/value table for any feature for any layer. You could also to more horizontal tables using the [items] tag to output one header row…
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Travis Kirstine
Sent: Tuesday, October 15, 2019 9:06 AM
To: mapserver-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [mapserver-users] wms servers html template output
This message may be from an external email source.
Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
Hi all,
I'm struggling a bit with using a generic template for html getfeatureinfo requests. Is there a easy way to create a simple html table containing the attribute field names and values for any layer. I don't want to create a separate template for each layer. Thanks
There was some mention of this here:
http://osgeo-org.1560.x6.nabble.com/Generic-template-for-WMS-GetFeatureInfo-td4227865.html<https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fosgeo-org.1560.x6.nabble.com%2FGeneric-template-for-WMS-GetFeatureInfo-td4227865.html&data=02%7C01%7Csteve.lime%40state.mn.us%7Caa1eb890540341ecbbab08d75178d454%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C637067451709877574&sdata=Dl5OEEEfUDw9q020aW453wCbHjNt9pOSMYDzQrW5QXo%3D&reserved=0>
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191016/8ab11226/attachment.htm>
More information about the MapServer-users
