[mapserver-users] Display of an RGB file
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Apr 14 12:28:34 PDT 2020
Hi Asen,
There seems to be several issues with your mapfile.
I found it easier to create my own small mapfile with your data:
https://gatewaygeomatics.com/dl/nasa-goddard-space-flight-center.map
Here it is in action:
https://ms4w.dev/cgi-bin/mapserv.exe?map=/ms4w/apps/ticket-nasa-goddard-space-flight-center/test.map&mode=browse&template=openlayers&layers=all
And you can add the WMS service into your local QGIS as a new WMS layer
using this url:
I'd recommend just starting with that mapfile locally, generate a map
image with a local 'shp2img' command, then test through the WMS service
in a client.
Hope that helps.  Cheers from the east coast of Canada,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
On 2020-04-14 12:43 p.m., Radov, Asen (GSFC-619.0)[UNIVERSITY OF
MARYLAND] wrote:
> Hello,
> I am trying to display a RGB file, but with no success.
> I was able to successfully display the RGB file in this
> example:https://demo.mapserver.org/tutorial/example1-5.html
> At this point, I think there is an issue with the file, maybe it is
> missing some geo location information, but I am not sure.
> Can someone double check if they can display this file? Any help is
> appreciated.
> Here is a link to it, since attaching It breaks the size limit:
> LC8_015030_20190727_rgb.tif
> <https://drive.google.com/file/d/1giMI5OPLU6SJZUhkK0ZxfySKSMP88G6G/view>
> Here is my map file for reference:
> MAP
>    IMAGETYPE PNG
>    EXTENT -180 -90 180 90
>    SIZE           256 256
>    SHAPEPATH      "/tis/stream/data"
>    # The regular expression below will match 1 or more letters followed by
>    # underscore followed by 1 or more numeric characters
>    DATAPATTERN    "[a-z]+|_|[0-9]+"
>    IMAGECOLOR     255 255 255
>    CONFIG "MS_ERRORFILE" "/usr/local/error.log"
>    DEBUG 5
>    SymbolSet "symbols/symbols.sym"
>    OUTPUTFORMAT
>      NAME "png"
>      DRIVER "AGG/PNG"
>      MIMETYPE "image/PNG"
>      IMAGEMODE RGBA
>      TRANSPARENT ON
>      EXTENSION "png"
>      FORMATOPTION "COMPRESSION=1"
>    END
>    PROJECTION
>      "init=epsg:4326"
>    END
>    WEB
>      METADATA
>        "wms_title"     "WMS STREAM Server"  ##required
>        "wms_onlineresource" "http://localhost:8181/cgi-bin/mapserv?"
> ##required
>        "wms_srs"       "EPSG:4326"  ##recommended
>        "wms_enable_request" "*"   ##necessary
>      END
>    END # Web
>    LAYER
>      NAME "rgb1"
>      DATA ""
>      PROCESSING "BANDS=1,2,3"
>      TYPE RASTER
>      STATUS ON
>      DEBUG 5
>      PROJECTION
>        "init=epsg:4326"
>      END
>      METADATA
>          wms_title "Tss range 0-1 layer"
>          wms_srs "epsg:4326"
>          wms_extent "-180 -90 180 90"
>      END
>    END
> END
> /Thank you, /
> /Asen Radov/
> /NASA Goddard Space Flight Center / Code 619/
> /Phone: 301-614-6517/
> /E-mail: asen.s.radov at nasa.gov <mailto:asen.s.radov at nasa.gov>/
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
