[mapserver-users] [EXTERNAL] re: Display of an RGB file
Radov, Asen (GSFC-619.0)[UNIVERSITY OF MARYLAND] asen.s.radov at nasa.gov
Tue Apr 14 12:20:08 PDT 2020
Brent,
That fixed it!
Thank you,
Asen Radov
NASA Goddard Space Flight Center / Code 619
Phone: 301-614-6517
E-mail: asen.s.radov at nasa.gov
On 4/14/20, 2:26 PM, "Brent Fraser" <bfraser at GeoAnalytic.com> wrote:
    Asen,
       Your layer projection needs to match the tif file's project.  I like to
    use
         PROJECTION
          AUTO
        END
     Best regards,
     Brent Fraser
     -------- Original Message --------
    > From: "Radov, Asen (GSFC-619.0)[UNIVERSITY OF MARYLAND]"
    <asen.s.radov at nasa.gov>
    > Sent: April 14, 2020 10:09 AM
    > To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
    > Subject: [mapserver-users] Display of an RGB file
    > Hello,
    > I am trying to display a RGB file, but with no success.
    > I was able to successfully display the RGB file in this example:
    https://urldefense.proofpoint.com/v2/url?u=https-3A__demo.mapserver.org_tutorial_example1-2D5.html&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=7tS7g2TMzqiaCddWGe6NdQTfaKJKlV5vEMKRjd8uNzk&e=
    > At this point, I think there is an issue with the file, maybe it is
    missing some geo location information, but I am not sure.
    > Can someone double check if they can display this file? Any help is
    appreciated.
    > Here is a link to it, since attaching It breaks the size limit:
    LC8_015030_20190727_rgb.tif<https://urldefense.proofpoint.com/v2/url?u=https-3A__drive.google.com_file_d_1giMI5OPLU6SJZUh&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=t6_qHyvShNeWvfs1AUdCZ2d7iHotPnSbQddxnPAXeco&e=
    kK0ZxfySKSMP88G6G/view>
    > Here is my map file for reference:
    > MAP
    > IMAGETYPE PNG
    > EXTENT -180 -90 180 90
    > SIZE 256 256
    > SHAPEPATH "/tis/stream/data"
    > # The regular expression below will match 1 or more letters followed by
    > # underscore followed by 1 or more numeric characters
    > DATAPATTERN "[a-z]+|_|[0-9]+"
    > IMAGECOLOR 255 255 255
    > CONFIG "MS_ERRORFILE" "/usr/local/error.log"
    > DEBUG 5
    > SymbolSet "symbols/symbols.sym"
    > OUTPUTFORMAT
    > NAME "png"
    > DRIVER "AGG/PNG"
    > MIMETYPE "image/PNG"
    > IMAGEMODE RGBA
    > TRANSPARENT ON
    > EXTENSION "png"
    > FORMATOPTION "COMPRESSION=1"
    > END
    > PROJECTION
    > "init=epsg:4326"
    > END
    > WEB
    > METADATA
    > "wms_title" "WMS STREAM Server" ##required
    > "wms_onlineresource" "https://urldefense.proofpoint.com/v2/url?u=http-3A__localhost-3A8181_cgi-2Dbin_mapserv-3F&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=XzNFCTwn-g-B8y1dAD5RNJxgqe5YoRIwXx6cNVAIODk&e= " ##required
    > "wms_srs" "EPSG:4326" ##recommended
    > "wms_enable_request" "*" ##necessary
    > END
    > END # Web
    > LAYER
    > NAME "rgb1"
    > DATA ""
    > PROCESSING "BANDS=1,2,3"
    > TYPE RASTER
    > STATUS ON
    > DEBUG 5
    > PROJECTION
    > "init=epsg:4326"
    > END
    > METADATA
    > wms_title "Tss range 0-1 layer"
    > wms_srs "epsg:4326"
    > wms_extent "-180 -90 180 90"
    > END
    > END
    > END
    > Thank you,
    > Asen Radov
    > Phone: 301-614-6517
    > E-mail: asen.s.radov at nasa.gov<mailto:asen.s.radov at nasa.gov>
    > _______________________________________________ mapserver-users mailing
    list mapserver-users at lists.osgeo.org
    https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_mapserver-2Dusers&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=TsGBaxXv-eKJGkLucMO-JB1uQoUkY28al7GPNoe6rbQ&e=
More information about the MapServer-users mailing list
