[mapserver-users] [EXTERNAL] re: Display of an RGB file
Radov, Asen (GSFC-619.0)[UNIVERSITY OF MARYLAND]
asen.s.radov at nasa.gov
Tue Apr 14 12:20:08 PDT 2020
Brent,
That fixed it!
Thank you,
Asen Radov
NASA Goddard Space Flight Center / Code 619
Phone: 301-614-6517
E-mail: asen.s.radov at nasa.gov
On 4/14/20, 2:26 PM, "Brent Fraser" <bfraser at GeoAnalytic.com> wrote:
Asen,
Your layer projection needs to match the tif file's project. I like to
use
PROJECTION
AUTO
END
Best regards,
Brent Fraser
-------- Original Message --------
> From: "Radov, Asen (GSFC-619.0)[UNIVERSITY OF MARYLAND]"
<asen.s.radov at nasa.gov>
> Sent: April 14, 2020 10:09 AM
> To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] Display of an RGB file
> Hello,
> I am trying to display a RGB file, but with no success.
> I was able to successfully display the RGB file in this example:
https://urldefense.proofpoint.com/v2/url?u=https-3A__demo.mapserver.org_tutorial_example1-2D5.html&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=7tS7g2TMzqiaCddWGe6NdQTfaKJKlV5vEMKRjd8uNzk&e=
> At this point, I think there is an issue with the file, maybe it is
missing some geo location information, but I am not sure.
> Can someone double check if they can display this file? Any help is
appreciated.
> Here is a link to it, since attaching It breaks the size limit:
LC8_015030_20190727_rgb.tif<https://urldefense.proofpoint.com/v2/url?u=https-3A__drive.google.com_file_d_1giMI5OPLU6SJZUh&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=t6_qHyvShNeWvfs1AUdCZ2d7iHotPnSbQddxnPAXeco&e=
kK0ZxfySKSMP88G6G/view>
> Here is my map file for reference:
> MAP
> IMAGETYPE PNG
> EXTENT -180 -90 180 90
> SIZE 256 256
> SHAPEPATH "/tis/stream/data"
> # The regular expression below will match 1 or more letters followed by
> # underscore followed by 1 or more numeric characters
> DATAPATTERN "[a-z]+|_|[0-9]+"
> IMAGECOLOR 255 255 255
> CONFIG "MS_ERRORFILE" "/usr/local/error.log"
> DEBUG 5
> SymbolSet "symbols/symbols.sym"
> OUTPUTFORMAT
> NAME "png"
> DRIVER "AGG/PNG"
> MIMETYPE "image/PNG"
> IMAGEMODE RGBA
> TRANSPARENT ON
> EXTENSION "png"
> FORMATOPTION "COMPRESSION=1"
> END
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_title" "WMS STREAM Server" ##required
> "wms_onlineresource" "https://urldefense.proofpoint.com/v2/url?u=http-3A__localhost-3A8181_cgi-2Dbin_mapserv-3F&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=XzNFCTwn-g-B8y1dAD5RNJxgqe5YoRIwXx6cNVAIODk&e= " ##required
> "wms_srs" "EPSG:4326" ##recommended
> "wms_enable_request" "*" ##necessary
> END
> END # Web
> LAYER
> NAME "rgb1"
> DATA ""
> PROCESSING "BANDS=1,2,3"
> TYPE RASTER
> STATUS ON
> DEBUG 5
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> wms_title "Tss range 0-1 layer"
> wms_srs "epsg:4326"
> wms_extent "-180 -90 180 90"
> END
> END
> END
> Thank you,
> Asen Radov
> Phone: 301-614-6517
> E-mail: asen.s.radov at nasa.gov<mailto:asen.s.radov at nasa.gov>
> _______________________________________________ mapserver-users mailing
list mapserver-users at lists.osgeo.org
https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_mapserver-2Dusers&d=DwICAg&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=e281LxOLUXWX77lCDwwDG7yS4rW9wU7C6637XRybRqc&m=7J2dlWOBN48x7YKqL_YaSKzwI6Z1wPRXV23-HnuK-bU&s=TsGBaxXv-eKJGkLucMO-JB1uQoUkY28al7GPNoe6rbQ&e=
