[mapserver-users] Display of an RGB file
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Apr 14 12:28:34 PDT 2020
Hi Asen,
There seems to be several issues with your mapfile.
I found it easier to create my own small mapfile with your data:
https://gatewaygeomatics.com/dl/nasa-goddard-space-flight-center.map
Here it is in action:
https://ms4w.dev/cgi-bin/mapserv.exe?map=/ms4w/apps/ticket-nasa-goddard-space-flight-center/test.map&mode=browse&template=openlayers&layers=all
And you can add the WMS service into your local QGIS as a new WMS layer
using this url:
I'd recommend just starting with that mapfile locally, generate a map
image with a local 'shp2img' command, then test through the WMS service
in a client.
Hope that helps. Cheers from the east coast of Canada,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
On 2020-04-14 12:43 p.m., Radov, Asen (GSFC-619.0)[UNIVERSITY OF
MARYLAND] wrote:
> Hello,
> I am trying to display a RGB file, but with no success.
> I was able to successfully display the RGB file in this
> example:https://demo.mapserver.org/tutorial/example1-5.html
> At this point, I think there is an issue with the file, maybe it is
> missing some geo location information, but I am not sure.
> Can someone double check if they can display this file? Any help is
> appreciated.
> Here is a link to it, since attaching It breaks the size limit:
> LC8_015030_20190727_rgb.tif
> <https://drive.google.com/file/d/1giMI5OPLU6SJZUhkK0ZxfySKSMP88G6G/view>
> Here is my map file for reference:
> MAP
> IMAGETYPE PNG
> EXTENT -180 -90 180 90
> SIZE 256 256
> SHAPEPATH "/tis/stream/data"
> # The regular expression below will match 1 or more letters followed by
> # underscore followed by 1 or more numeric characters
> DATAPATTERN "[a-z]+|_|[0-9]+"
> IMAGECOLOR 255 255 255
> CONFIG "MS_ERRORFILE" "/usr/local/error.log"
> DEBUG 5
> SymbolSet "symbols/symbols.sym"
> OUTPUTFORMAT
> NAME "png"
> DRIVER "AGG/PNG"
> MIMETYPE "image/PNG"
> IMAGEMODE RGBA
> TRANSPARENT ON
> EXTENSION "png"
> FORMATOPTION "COMPRESSION=1"
> END
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_title" "WMS STREAM Server" ##required
> "wms_onlineresource" "http://localhost:8181/cgi-bin/mapserv?"
> ##required
> "wms_srs" "EPSG:4326" ##recommended
> "wms_enable_request" "*" ##necessary
> END
> END # Web
> LAYER
> NAME "rgb1"
> DATA ""
> PROCESSING "BANDS=1,2,3"
> TYPE RASTER
> STATUS ON
> DEBUG 5
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> wms_title "Tss range 0-1 layer"
> wms_srs "epsg:4326"
> wms_extent "-180 -90 180 90"
> END
> END
> END
> /Thank you, /
> /Asen Radov/
> /NASA Goddard Space Flight Center / Code 619/
> /Phone: 301-614-6517/
> /E-mail: asen.s.radov at nasa.gov <mailto:asen.s.radov at nasa.gov>/
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
