[mapserver-users] OUTPUTFORMAT png 16-bits
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Wed Feb 5 06:50:06 PST 2020
Hi Jukka,
you're damn right. Missed that he uses the GDAL-driver. Seems to be exactly as you say. For IMAGEMODE INT16 MapServer maps it to GDT_Int16 (https://github.com/mapserver/mapserver/blob/master/mapgdal.c#L234). But GDAL's PNG-driver checks for GDT_UInt16 (https://github.com/OSGeo/gdal/blob/master/gdal/frmts/png/pngdataset.cpp#L1477) and maps everything else to bitdepth=8
-----Ursprüngliche Nachricht-----
Von: Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi]
Gesendet: Mittwoch, 5. Februar 2020 14:57
An: Eichner, Andreas - SID; Johannes Paul
Cc: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] OUTPUTFORMAT png 16-bits
But it is GDAL that is supposed to write the png because of
DRIVER GDAL/PNG
GDAL does support UInt16 fot png but it does not support int16. Perhaps this has something to do with the problem.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Eichner, Andreas - SID <Andreas.Eichner at sid.sachsen.de>
Lähetetty: keskiviikko 5. helmikuuta 2020 13.05
Vastaanottaja: Johannes Paul <johannespaul92 at gmail.com>; Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: mapserver-users at lists.osgeo.org
Aihe: AW: [mapserver-users] OUTPUTFORMAT png 16-bits
Hello Johannes,
16bit-PNGs are IMHO not supported by MapServer. Although libPNG supports 16bit depth (see http://www.libpng.org/pub/png/libpng-1.2.5-manual.html#section-4.3) MapServer only supports 1, 2, 4 and 8bit palettes (see https://github.com/mapserver/mapserver/blob/master/mapimageio.c#L355).
HTH
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Johannes Paul
Gesendet: Mittwoch, 5. Februar 2020 11:33
An: Rahkonen Jukka (MML)
Hello Jukka,
Thanks for your reply, i've changed mimetype but i still get the 8-bits png...
Johannes
Le mer. 5 févr. 2020 à 11:09, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> a écrit :
I would make a test by using some other mimetype, like image/png16, for eliminating the possibility that some internal png configuration drives over your own outputformat.
I don’t know if it helps but it is cheap to test.
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Johannes Paul
Lähetetty: keskiviikko 5. helmikuuta 2020 12.03
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] OUTPUTFORMAT png 16-bits
Hello,
I'm using Mapserver to output PNG 16-bits DEM raster from .HGT elevation data.
I'm using the below output format definition :
OUTPUTFORMAT
NAME PNG16
DRIVER GDAL/PNG
MIMETYPE image/png
IMAGEMODE INT16
EXTENSION "png"
END
However I keep on getting the standard PNG 8-bits out of mapserver.
The strange thing being that when I use a similar config to get GeoTiff 16-bits, I do get what I'm asking for :
OUTPUTFORMAT
NAME GEOTIFF16
DRIVER GDAL/GTiff
MIMETYPE image/tiff
IMAGEMODE INT16
EXTENSION "tiff"
END
Could that be an issue with the GDAL/PNG driver ? It seems that the GDAL/PNG driver supports only CreateCopy() and not Create(), where the GDAL/GTiff driver supports both ... Could that be it ? I suspect the GDAL/PNG driver so I also sent my issue to the GDAL mailing list.
I can see from the mailing list that other users already had a similar issue, but there is no obvious reason or solution provided.
https://lists.osgeo.org/pipermail/mapserver-users/2011-April/068428.html
https://lists.osgeo.org/pipermail/mapserver-users/2012-January/071310.html
For information, I'm using GDAL v2.1.3 and Mapserver v7.0.1
Thanks,
Johannes
More information about the MapServer-users
