[mapserver-users] OUTPUTFORMAT png 16-bits
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Feb 5 07:52:10 PST 2020
Hi Johannes,
I just wanted to mention that what I always test OUTPUTFORMAT with is
through the shp2img commandline utility, with the "-i" switch, such as:
shp2img -m test.map -o ttt.png -i PNG16 -all_debug 5
PS. in the future MapServer v8.0 I hope to help change that utility name
to "map2img", so it makes more sense.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-02-05 6:02 a.m., Johannes Paul wrote:
> Hello,
> I'm using Mapserver to output PNG 16-bits DEM raster from .HGT elevation
> data.
> I'm using the below output format definition :
> |OUTPUTFORMAT NAME PNG16 DRIVER GDAL/PNG MIMETYPE image/png IMAGEMODE
> INT16 EXTENSION "png" END|
> However I keep on getting the standard PNG 8-bits out of mapserver.
> The strange thing being that when I use a similar config to get GeoTiff
> 16-bits, I do get what I'm asking for :
> OUTPUTFORMAT
> NAME GEOTIFF16
> DRIVER GDAL/GTiff
> MIMETYPE image/tiff
> IMAGEMODE INT16
> EXTENSION "tiff"
> END
> Could that be an issue with the GDAL/PNG driver ? It seems that the
> GDAL/PNG driver supports only CreateCopy() and not Create(), where the
> GDAL/GTiff driver supports both ... Could that be it ? I suspect the
> GDAL/PNG driver so I also sent my issue to the GDAL mailing list.
> I can see from the mailing list that other users already had a similar
> issue, but there is no obvious reason or solution provided.
> https://lists.osgeo.org/pipermail/mapserver-users/2011-April/068428.html
> https://lists.osgeo.org/pipermail/mapserver-users/2012-January/071310.html
> For information, I'm using GDAL v2.1.3 and Mapserver v7.0.1
> Thanks,
> Johannes
More information about the MapServer-users
