[mapserver-users] cgi-error: End of script output before headers mapserv
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Wed Jan 22 06:21:57 PST 2020
Hello Jeff,
is shp2img exactly the same as mapserv? (My thought was to use the same
executable the webserver calls)
Jo,
did you get a proper result (image) from your command line request? the
'error'-messages look quite OK.
Jörg
Am 22.01.20 um 15:12 schrieb Jeff McKenna:
> Hi Jo,
> Are you passing the problem extents to the shp2img utility? Such as:
> shp2img -m osm-transp-en-default.map -e -9.1433 38.7460 -9.1406
> 38.7487 -o ttt.png -all_debug 5
> If that doesn't help, then I would start from the beginning: execute a
> GetCapabilities request and make sure you remove all "WARNING" messages.
> -jeff
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users
