[mapserver-users] cgi-error: End of script output before headers mapserv
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jan 22 06:28:48 PST 2020
The more tests the better :)
-jeff
On 2020-01-22 10:21 a.m., Jörg Thomsen (WhereGroup) wrote:
> Hello Jeff,
> is shp2img exactly the same as mapserv? (My thought was to use the same
> executable the webserver calls)
> Jo,
> did you get a proper result (image) from your command line request? the
> 'error'-messages look quite OK.
> Jörg
> Am 22.01.20 um 15:12 schrieb Jeff McKenna:
>> Hi Jo,
>> Are you passing the problem extents to the shp2img utility? Such as:
>> shp2img -m osm-transp-en-default.map -e -9.1433 38.7460 -9.1406
>> 38.7487 -o ttt.png -all_debug 5
>> If that doesn't help, then I would start from the beginning: execute a
>> GetCapabilities request and make sure you remove all "WARNING" messages.
>> -jeff
> Viele Grüße,
> Jörg Thomsen
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the MapServer-users
