[mapserver-users] MapCache dimensions with MapServer run time substitution
Travis Kirstine
traviskirstine at gmail.com
Tue Jul 7 10:36:18 PDT 2020
Is it possible to utilize mapcache regex dimensions with mapserver run time
substitution (wms) to create a more dynamic and generic tile service
Here is my basic configuration for mapserver and mapcache, I can't seem to
get it working with QGIS when connecting to the WMTS
For example I use run time substitution with my PG DATA settings
LAYER
NAME "sub_layer"
VALIDATION
'layer_table' ^.*$'
'layer_class' '^.*$'
END
CONNECTIONTYPE postgis
CONNECTION "port=9999 user=user password=pw dbname=db host=mydb"
DATA "the_geom from (SELECT gid, ms_color, the_geom FROM %layer_table%
WHERE class='%layer_class%') AS foo USING UNIQUE gid using SRID=4326"
END
I set my MapCache config up with the same runtime variables as dimensions
<source name="source_wms" type="wms">
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<TRANSPARENT>true</TRANSPARENT>
<LAYERS>sub_layer</LAYERS>
</params>
</getmap>
<http>
<url>http://testserver.com/cgi-bin/wms?</url>
</http>
</source>
<tileset name="tileset_regex">
<source>source_wms</source>
<cache>composite</cache>
<grid>GoogleMapsCompatible</grid>
<format>PNG</format>
<metatile>5 5</metatile>
<metabuffer>10</metabuffer>
<expires>3600</expires>
<auto_expire>604800</auto_expire>
<dimensions>
<dimension type="regex" name="layer_class" default="none">
<regex>^.*$</regex>
</dimension>
<dimension type="regex" name="layer_table" default="none">
<regex>^.*$</regex>
</dimension>
</dimensions>
</tileset>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200707/ea84d114/attachment.html>
