[mapserver-users] MAXSCALEDENOM using runtime var
Scott
public at postholer.com
Tue Jun 16 14:50:54 PDT 2020
Thanks for the response.
My mapserv binary is in a wrapper so I have control over dubious
features I may (intentionally) introduce.
With that said, if it's not readily available and only available via
modification, someone more knowledgeable had good reason. I'll think of
a different approach.
Thanks again!
On 6/16/20 1:56 PM, Steve Lime wrote:
> Hi Scott: Nope, the various scale denominator properties are not mutable
> via URL parameters. It's a relatively simple change to make it happen
> (just modify maplexer.l (look for the keyword of choice) and rebuild)
> but I'm not sure it's a great idea since you could be opening up some
> performance headaches for both your mapping box and backend data
> sources. I mean, a user could essentially affect at what level high
> density data could be drawn at, so imagine asking for high density roads
> at a global scale from a remote PostgreSQL/PostGIS source.
> --Steve
> On Tue, Jun 16, 2020 at 3:36 PM Scott <public at postholer.com
> <mailto:public at postholer.com>> wrote:
> Is it possible to set MAX(MIN)SCALEDENOM using a runtime variable?
> Example:
> MAXSCALEDENOM %maxscaledenom%
> www.postholer.com <http://www.postholer.com>
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
