[mapserver-users] PostGIS Raster Filters
brett.winklesky at gmail.com
Thu Jun 18 08:09:02 PDT 2020
Hello-
I'm trying to setup a WMS layer that is reading a raster table in PostGIS.
I am loading NOAA Global Hydro Estimation data in a single table (tiled) and
have a field that contains the datetime for the raster. I followed the
examples here:
https://postgis.net/docs/RT_FAQ.html#idm29732
In my case I would like to use the "where" statement to filter the raster
tiles, but the 'where' statement only seems to work with the 'rid' field
(e.g. rid=123). Based on the example in the PostGIS docs, it looks like it
should theoretically work. I tried the "FILTER" in the map file, but I
assume that only works with vector data since it did nothing.
Does anybody know the trick to filter tiled raster data from a PostGIS
raster table?
Any help is greatly appreciated!
Cheers,
BW
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200618/20848cce/attachment.htm>
More information about the MapServer-users
