[mapserver-users] PostGIS query problem
Fernando Martins Pimenta
fernando.m.pimenta at gmail.com
Thu Jun 25 13:16:33 PDT 2020
I am using the query below to return a hydrograph of a region (using
POSTGIS). This query works perfectly when I use it in pgadmin. With the
mapserver, the connection with the client is lost. It records a query that
shows no errors in SQL, just shows that the connection has lost. Why is
that?
DATA "geom FROM (
SELECT
hidro.fid, hidro.name, ST_Intersection(gcc.geom, hidro.geom) AS
geom
FROM
vector.hidrography AS hidro,
vector.gcc AS gcc
WHERE ST_Intersects(gcc.geom, hidro.geom) AND gcc.name = 'GRANDE'
) as subquery USING UNIQUE fid USING SRID=4326"
Thanks in advance
*Fernando Martins Pimenta <http://lattes.cnpq.br/0646984654461300>*
Graduando em Engenharia de Agrimensura e Cartográfica - UFV
Bacharel em Engenharia de Biossistemas - UFSJ
www.biosfera.dea.ufv.br
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200625/e300a5d6/attachment.html>
