[mapserver-users] php_mapscript throubleshoot
Richard Greenwood richard.greenwood at gmail.com
Tue Mar 10 18:46:41 PDT 2020
Shouldn't php_mapscript.so be in /usr/lib/php/20170718/ or similar? I'm on
Ubuntu so maybe it's different on Centos.
Also note that you have compiled two different version of mapscript so you
should have both php_mapscript.so and php_mapscriptng.so
On Fri, Mar 6, 2020 at 7:38 AM Domenico Febbo <domenico.febbo at gmail.com>
wrote:
> Dears
> after successully compilation of mapserver 7.4.3 on centos 8,
> I'm not able to load  php_mapscript on PHP environment, (nothing related
> to mapscript is displayed on phpinfo();
> some info:
> cmake
>  -DCMAKE_PREFIX_PATH="/usr/geos38;/usr/proj63;/usr/gdal30;/usr/pgsql-12;/usr/local"
> -DWITH_PHPNG=ON -DWITH_CLIENT_WFS=ON -DWITH_CLIENT_WMS=ON  -DWITH_CURL=ON
> -DWITH_SVGCAIRO=OFF -DWITH_PROTOBUFC=OFF -DWITH_CAIRO=OFF -DWITH_FRIBIDI=ON
> -DWITH_HARFBUZZ=ON -DWITH_GEOS=ON ../
> -- /usr/include/php/main
> -- Found PHP-Version 7.2.11 (using /usr/bin/php-config)
> -- Found SWIG: /usr/local/bin/swig (found version "4.0.1")
> -- PHP Include Path:
> /usr/include/php;/usr/local/include/php;/usr/include/php;/usr/local/include/php;/usr/local/apache/php;/usr/include/php/Zend;/usr/include/php/main;/usr/include/php/TSRM;INTERNAL;PHP
> include paths
> -- * Summary of configured options for this build
> --  * Mandatory components
> --   * png: /usr/lib64/libpng.so
> --   * jpeg: /usr/lib64/libjpeg.so
> --   * freetype: /usr/lib64/libfreetype.so
> --  * Optional components
> --   * GDAL: /usr/gdal30/lib/libgdal.so
> --   * OGR: /usr/gdal30/lib/libgdal.so
> --   * GIF: /usr/lib64/libgif.so
> --   * MYSQL: disabled
> --   * FRIBIDI: /usr/lib64/libfribidi.so
> --   * HARFBUZZ: /usr/lib64/libharfbuzz.so
> --   * CAIRO: disabled
> --   * SVGCAIRO: disabled
> --   * RSVG: disabled
> --   * CURL: /usr/lib64/libcurl.so
> --   * PROJ: /usr/proj63/lib/libproj.so
> --   * PIXMAN: disabled
> --   * LIBXML2: /usr/lib64/libxml2.so
> --   * POSTGIS: /usr/pgsql-12/lib/libpq.so
> --   * GEOS: /usr/geos38/lib64/libgeos_c.so
> --   * FastCGI: /usr/lib64/libfcgi.so
> --   * PROTOBUFC: disabled
> --   * Oracle Spatial: disabled
> --   * Exempi XMP: disabled
> --  * Optional features
> --   * WMS SERVER: ENABLED
> --   * WFS SERVER: ENABLED
> --   * WCS SERVER: ENABLED
> --   * SOS SERVER: disabled
> --   * WMS CLIENT: ENABLED
> --   * WFS CLIENT: ENABLED
> --   * ICONV: ENABLED
> --   * Thread-safety support: disabled
> --   * KML output: disabled
> --   * Z+M point coordinate support: disabled
> --   * XML Mapfile support: disabled
> --  * Mapscripts
> --   * Python: disabled
> --   * PHP: ENABLED
> --   * PHPNG: ENABLED
> --   * PERL: disabled
> --   * RUBY: disabled
> --   * JAVA: disabled
> --   * C#: disabled
> --   * V8 Javascript: disabled
> --   * Apache Module (Experimental): disabled
> -- Will install files to /usr/local
> -- Will install libraries to /usr/local/lib
> -- Configuring done
> -- Generating done
> after make; make install
> I can check:
> # mapserv -v
> MapServer version 7.4.3 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> lib is in the right place:
> /usr/lib64/php/modules/php_mapscript.so
> and extension is configured:
> /etc/php.d/30-php_mapscript.ini
> ; Enable mapserver extension module
> extension=php_mapscript
> Do you have any idea how to check if the module is loaded?
> Regards,
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200310/1331d597/attachment.htm>
More information about the MapServer-users mailing list
