[mapserver-users] php_mapscript throubleshoot
Domenico Febbo
domenico.febbo at gmail.com
Fri Mar 6 06:38:42 PST 2020
Dears
after successully compilation of mapserver 7.4.3 on centos 8,
I'm not able to load php_mapscript on PHP environment, (nothing related to
mapscript is displayed on phpinfo();
some info:
cmake
-DCMAKE_PREFIX_PATH="/usr/geos38;/usr/proj63;/usr/gdal30;/usr/pgsql-12;/usr/local"
-DWITH_PHPNG=ON -DWITH_CLIENT_WFS=ON -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON
-DWITH_SVGCAIRO=OFF -DWITH_PROTOBUFC=OFF -DWITH_CAIRO=OFF -DWITH_FRIBIDI=ON
-DWITH_HARFBUZZ=ON -DWITH_GEOS=ON ../
-- /usr/include/php/main
-- Found PHP-Version 7.2.11 (using /usr/bin/php-config)
-- Found SWIG: /usr/local/bin/swig (found version "4.0.1")
-- PHP Include Path:
/usr/include/php;/usr/local/include/php;/usr/include/php;/usr/local/include/php;/usr/local/apache/php;/usr/include/php/Zend;/usr/include/php/main;/usr/include/php/TSRM;INTERNAL;PHP
include paths
-- * Summary of configured options for this build
-- * Mandatory components
-- * png: /usr/lib64/libpng.so
-- * jpeg: /usr/lib64/libjpeg.so
-- * freetype: /usr/lib64/libfreetype.so
-- * Optional components
-- * GDAL: /usr/gdal30/lib/libgdal.so
-- * OGR: /usr/gdal30/lib/libgdal.so
-- * GIF: /usr/lib64/libgif.so
-- * MYSQL: disabled
-- * FRIBIDI: /usr/lib64/libfribidi.so
-- * HARFBUZZ: /usr/lib64/libharfbuzz.so
-- * CAIRO: disabled
-- * SVGCAIRO: disabled
-- * RSVG: disabled
-- * CURL: /usr/lib64/libcurl.so
-- * PROJ: /usr/proj63/lib/libproj.so
-- * PIXMAN: disabled
-- * LIBXML2: /usr/lib64/libxml2.so
-- * POSTGIS: /usr/pgsql-12/lib/libpq.so
-- * GEOS: /usr/geos38/lib64/libgeos_c.so
-- * FastCGI: /usr/lib64/libfcgi.so
-- * PROTOBUFC: disabled
-- * Oracle Spatial: disabled
-- * Exempi XMP: disabled
-- * Optional features
-- * WMS SERVER: ENABLED
-- * WFS SERVER: ENABLED
-- * WCS SERVER: ENABLED
-- * SOS SERVER: disabled
-- * WMS CLIENT: ENABLED
-- * WFS CLIENT: ENABLED
-- * ICONV: ENABLED
-- * Thread-safety support: disabled
-- * KML output: disabled
-- * Z+M point coordinate support: disabled
-- * XML Mapfile support: disabled
-- * Mapscripts
-- * Python: disabled
-- * PHP: ENABLED
-- * PHPNG: ENABLED
-- * PERL: disabled
-- * RUBY: disabled
-- * JAVA: disabled
-- * C#: disabled
-- * V8 Javascript: disabled
-- * Apache Module (Experimental): disabled
-- Will install files to /usr/local
-- Will install libraries to /usr/local/lib
-- Configuring done
-- Generating done
after make; make install
I can check:
# mapserv -v
MapServer version 7.4.3 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
lib is in the right place:
/usr/lib64/php/modules/php_mapscript.so
and extension is configured:
/etc/php.d/30-php_mapscript.ini
; Enable mapserver extension module
extension=php_mapscript
Do you have any idea how to check if the module is loaded?
Regards,
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200306/1ecc8b4f/attachment.htm>
More information about the MapServer-users
