[mapserver-users] mapserver 7.4.3 on centos 8 and gdal 3.0.4
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Mar 11 04:31:14 PDT 2020
Glad you solved it.
Related tip: GEOS 3.8.1 is now available.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-03-05 6:03 p.m., Domenico Febbo wrote:
> Dears
> issue was solved as you suggested arranging right version of GEOS, GDAL
> and PROJ
> see my working cmake command
> cmake
>   -DCMAKE_PREFIX_PATH="/usr/geos38;/usr/proj63;/usr/gdal30;/usr/pgsql-12;/usr/local" -DWITH_CLIENT_WFS=OFF -DWITH_CLIENT_WMS=ON  -DWITH_CURL=ON -DWITH_PHP=ON -DWITH_SVGCAIRO=OFF -DWITH_PROTOBUFC=OFF -DWITH_CAIRO=OFF -DWITH_FRIBIDI=OFF -DWITH_HARFBUZZ=OFF -DWITH_GEOS=ON ../
>   Regards,
>     Date: Thu, 05 Mar 2020 18:23:11 +0100
>     From: Even Rouault <even.rouault at spatialys.com
>     <mailto:even.rouault at spatialys.com>>
>     To: mapserver-users at lists.osgeo.org
>     <mailto:mapserver-users at lists.osgeo.org>
>     Subject: Re: [mapserver-users] mapserver 7.4.3 on centos 8 and gdal
>              3.0.4
>     Message-ID: <5264658.HpSgdfGQFN at even-i700>
>     Content-Type: text/plain; charset="us-ascii"
>     On jeudi 5 mars 2020 13:11:59 CET Jeff McKenna wrote:
>      > Also, recompile GDAL after you build GEOS 3.8.0, as GDAL >3 requires
>      > GEOS.  -jeff
>     There's no GDAL > 3 for now ;-) But, joke aside, GDAL 3 doesn't change
>     requirements regarding GEOS. GEOS is a recommended dependency, but
>     not a
>     compulsory one. Only PROJ >= 6 is a compulsory dependency for GDAL >= 3
>     Even
More information about the MapServer-users mailing list
