[mapserver-users] MapServer WFS server with PostGIS doesn't
Passmore, James H.
jpass at bgs.ac.uk
Mon Mar 9 04:35:12 PDT 2020
Not sure
Date: Wed, 4 Mar 2020 11:58:48 +0100
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] MapServer WFS server with PostGIS doesn't
respects the axis order defined by the EPSG definition
Message-ID: <5523EFD9-FC06-46A1-9023-6A96AE5F182E at mapcentia.com>
Content-Type: text/plain;charset=utf-8
> The 1.1.0 request the axis order is being flipped in the WHERE clause (is lat/lon). But shouldn't WFS 1.1.0 respect the axis order defined by the EPSG definition?
I'm not sure I understand this statement in your question. The EPSG:4326 definition (http://www.epsg-registry.org/export.htm?wkt=urn:ogc:def:crs:EPSG::4326) is lat/long.
James
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system.
UK Research and Innovation has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UK Research and Innovation does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Opinions, conclusions or other information in this message and attachments that are not related directly to UK Research and Innovation business are solely those of the author and do not represent the views of UK Research and Innovation.
