[mapserver-users] MapScript PHP label with expression and linebreak
Jean-Philippe Chenel
jp.chenel at LIVE.CA
Sat Mar 28 07:22:39 PDT 2020
Using MapScript PHP API, I want to create a label object (using tostring expression) and put 2 columns with a linebreak between them.
The example above is working well on a single line, but I don’t know how to make the linebreak (carriage return).
$text = "(tostring([vol],'%.2f')+'[vol]')";
$classObj = new classObj($layer);
$classObj->setText($text);
$classObj->addLabel(CreateNewLabel($labelProperties));
I've tried multiple combination of \r\n but none of them work (map rendering work, but the label completely disappear).
$text = "(tostring([vol],'%.2f') + '\r\n[vol]')";
$text = "(tostring([vol],'%.2f') + '\r\n' + '[vol]')";
If I don’t use the expression, the line break work
$text = "'[vol]\r\n[vol]'";
By the way, the TEXT property is on the classObj, the setText method doesn’t work on the labelObj.
With best regards,
MapServer 7.4.4 (under ubuntu 16.04)
PHP 5.6.40
Jean-Philippe
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200328/8ca606f2/attachment.html>
