[mapserver-users] Characters breaks variable substitution in TEXT parameter
Nicol Hermann
mapserver at geoworld.de
Sat Mar 28 09:36:24 PDT 2020
Hey Jeff,
thanks for your feedback.
It was obviously an issue with version 7.4.3
An upgrade to 7.4.4 solved the problem.
Thanks for your help and greetings to Canada
Nicol
Am Samstag, den 28.03.2020, 10:07 -0300 schrieb Jeff McKenna:
> Hi Nicol,
> I have just tested this locally and the following does work:
> TEXT "[attribute1] - [attribute2] - [attribute3]"
> as well as
> TEXT "[attribute1]-[attribute2]-[attribute3]"
> Both produce expected map/label results with shp2img. I am testing
> with
> MS4W 4.0.3 (MapServer 7.6.0-dev).
> You can see my mapfile (I use inline features, so you could even
> paste
> the feature locally to test):
> https://ms4w.dev/text-multiple/text-multiple.map
> Here is the map output:
> https://ms4w.dev/cgi-bin/mapserv.exe?map=/ms4w/apps/ticket-text-multiple/text-multiple.map&layers=all&mode=browse&template=openlayers
> Hope I am understanding your question properly. And good morning
> from
> the east coast of Canada,
> -jeff
