[mapserver-users] WCS GetCoverage request one by one pixel
Even Rouault
even.rouault at spatialys.com
Sat May 9 11:40:59 PDT 2020
Anton,
> I quickly skimmed the issue tracker on Github but could not find any issue
> causing this problem. Any thoughts on the cause of the problem are highly
> appreciated.
I believe this is a bug in MapServer due to a difference between pixel-center vs
pixel-corner convention between WCS conventions and MapServer conventions,
which must lead to an empty bounding box when the request is 1x1, and thus
causing invalid resolution to be computed at some point (division by zero). This
could presumably be fixed
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200509/46b3dd09/attachment.htm>
More information about the MapServer-users
