[mapserver-users] WCS GetCoverage request one by one pixel
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon May 11 04:02:50 PDT 2020
I verified the error and I am pretty sure that subsetting with min=max has been working for me couple of years ago with some Mapserver version.
This sends a GeoTIFF:
http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w_data\raster_test.map&service=WCS&version=2.0.1&request=GetCoverage&CoverageID=natural_earth&SUBSET=long(27,28)&SUBSET=lat(62,63)
This sends an error:
http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w_data\raster_test.map&service=WCS&version=2.0.1&request=GetCoverage&CoverageID=natural_earth&SUBSET=long(27,27)&SUBSET=lat(62,62)
msImageCreate(): Image handling error. Attempt to allocate raw image failed, out of memory.
I believe that 1x1 pixel image is expected because WCS 2.0.1 standard defines that the request is OK.
"Then, for the trim bounds trimLow and trimHigh the following
shall hold: L <= trimLow <= trimHigh <= H"
Here is my MS4W mapfile for the Natural Earth raster https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/50m/raster/NE1_50M_SR_W.zip<https://www.naturalearthdata.com/http/www.naturalearthdata.com/download/50m/raster/NE1_50M_SR_W.zip>
MAP
NAME ""
STATUS ON
MAXSIZE 5000
CONFIG "MS_ERRORFILE" "c:\ms4w_data\test_error.txt"
#DEBUG 3
EXTENT -180 -90 180 90
SIZE 600 600
#SHAPEPATH "c:\ms4w\tmp\ms_tmp"
IMAGECOLOR 255 255 255
UNITS METERS
WEB
#IMAGEPATH "c:\ms4w\tmp\ms_tmp"
#IMAGEURL "c:\ms4w\tmp\ms_tmp"
METADATA
"ows_enable_request" "*"
"wms_srs" "EPSG:4326"
"ows_onlineresource" "http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w_data\test.map"
"wms_title" "wms-test"
"wcs_label" "wcs-test" ### required
"wcs_description" "wcs-test"
"wcs_enable_request" "*"
END
END
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME 'AGG_Q'
MIMETYPE "image/png" DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
OUTPUTFORMAT
NAME GEOTIFF
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE BYTE
EXTENSION "tif"
END
LAYER
NAME "natural_earth"
TYPE RASTER
STATUS ON
DATA "c:\ms4w_data\ne_raster\NE1_50M_SR_W.tif"
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "ne_raster"
"wcs_title" "ne_raster"
END
END #layer
END #map
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Even Rouault
Lähetetty: lauantai 9. toukokuuta 2020 21.41
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] WCS GetCoverage request one by one pixel
Anton,
> I quickly skimmed the issue tracker on Github but could not find any issue
> causing this problem. Any thoughts on the cause of the problem are highly
> appreciated.
I believe this is a bug in MapServer due to a difference between pixel-center vs pixel-corner convention between WCS conventions and MapServer conventions, which must lead to an empty bounding box when the request is 1x1, and thus causing invalid resolution to be computed at some point (division by zero). This could presumably be fixed
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200511/5d4b13c7/attachment.htm>
More information about the MapServer-users
