[mapserver-users] Version 7.7 & proj.db
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Nov 24 06:50:19 PST 2020
Since you are not compiling PROJ/GDAL yourself, you should ask the
packagers directly.  (for example, on Debian: debian-gis (at)
lists.debian.org )
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-11-24 10:40 a.m., aimdev at mail.com wrote:
> Hi
> I used
> proj-bin/testing,now 7.2.0-1 amd64 [installed]
> proj-data/testing,now 7.2.0-1 all [installed,automatic]
> libproj-dev/testing,now 7.2.0-1 amd64 [installed,automatic]
> and
> gdal-bin/testing,now 3.1.4+dfsg-1+b1 amd64 [installed]
> gdal-data/testing,now 3.1.4+dfsg-1 all [installed]
> libgdal-dev/testing,now 3.1.4+dfsg-1+b1 amd64 [installed]
> These are the ones available from the Bullseye repository.
> I am not clear where the proj.db file would have been installed, and
> where it should go / how it is referenced in the MapServer directory
> structure.
>  From my point of view the map looks the same as the existing
>> On 24 Nov 2020, at 12:28, Jeff McKenna <jmckenna at gatewaygeomatics.com
>> <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>> On 2020-11-24 8:18 a.m., Jeff McKenna wrote:
>>> On 2020-11-24 8:12 a.m., Jeff McKenna wrote:
>>>> Master now requires PROJ 7 (and PROJ now requires SQLite, LibTIFF,
>>>> Curl).  The PROJ build process should generate 'proj.db' inside
>>>> /data, and 'make install' should place that file in something like
>>>> /usr/local/share/proj/proj.db
>>>> Make sure that GDAL and MapServer are built with PROJ 7 (7.2.0 is
>>>> recommended).
>>>> -jeff
>>> Be careful also that if you have compiled the GeoTIFF library
>>> yourself, that it also requires PROJ (and therefore PROJ 7).  I've
>>> had to recompile that on many client systems.
>>> -jeff
>> and GDAL 3.2.0 is recommended with PROJ 7.2.0
>> clear as mud? :)
>> Hello from the east coast of Canada,
>> Jeff McKenna
>> http://gatewaygeo.com/ <http://gatewaygeo.com/>
More information about the MapServer-users mailing list
