[mapserver-users] Error compiling 7.4.4 and 7.4.0
Stéphane Poissant spoissantca at gmail.com
Wed Nov 25 05:32:52 PST 2020
Hello everyone,
I am upgrading an old installation that runs 7.0,7
It used to run on amazon linux 1. (CentOS 6)
I am compiling the 7.4.x version for Amazon linux 2 (CentOS 7).
I configure the cmake flags and I am able to "make" successfully.
I get the bottom described error while doing "make install". Looks like 90%
goes through but it fails when it comes to Java or Perl or both (if flagged
ON).
Environment:
   - Amazon linux 2 virtual server (CentOS 7)
   - Proj 6.1.1 compiled
   - Gdal 3.2.0 compiled
(perl-devel and other perl-*devel installed too..)
Makefile option set as follow:
CMAKEFLAGS=-DCMAKE_C_FLAGS="--coverage ${CMAKE_C_FLAGS}"
-DCMAKE_CXX_FLAGS="--coverage ${CMAKE_CXX_FLAGS}"
-DCMAKE_SHARED_LINKER_FLAGS="-lgcov"
-DWITH_CLIENT_WMS=1
-DWITH_CLIENT_WFS=1
-DWITH_KML=1
-DWITH_SOS=1
-DWITH_CSHARP=1
-DWITH_PHP=0
-DWITH_PERL=1
-DWITH_PHPNG=1
-DWITH_PYTHON=1
-DWITH_JAVA=1
-DWITH_THREAD_SAFETY=1
-DWITH_FRIBIDI=1
-DWITH_FCGI=0
-DWITH_EXEMPI=0
-DWITH_RUBY=0
-DCMAKE_BUILD_TYPE=Release
-DWITH_RSVG=0
-DWITH_CURL=1
-DWITH_HARFBUZZ=1
-DWITH_POINT_Z_M=1
${EXTRA_CMAKEFLAGS}
Compiling mapserver 7.4.4...
(success) # cd /root/inst/mapserver-7.4.4
(success) # make
(success) # cd build/ 246558
(fail)# make install
creating 'dist/mapscript-7.4.4-py2.7-linux-x86_64.egg' and adding
'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing mapscript-7.4.4-py2.7-linux-x86_64.egg
removing '/usr/local/lib/python2.7/site-packages/mapscript-7.4.4-py2.7-linux-x86_64.egg'
creating /usr/local/lib/python2.7/site-packages/mapscript-7.4.4-py2.7-linux-x86_64.egg
Extracting mapscript-7.4.4-py2.7-linux-x86_64.egg to
mapscript 7.4.4 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/site-packages/mapscript-7.4.4-py2.7-linux-x86_64.egg
Processing dependencies for mapscript==7.4.4
Finished processing dependencies for mapscript==7.4.4
-- Installing: /usr/lib64/php/modules/libphp_mapscriptng.so
-- Set runtime path of "/usr/lib64/php/modules/libphp_mapscriptng.so"
to "/usr/local/lib64:/usr/local/lib"
CMake Error at mapscript/perl/cmake_install.cmake:44 (FILE):
  file INSTALL cannot find
  "/root/inst/mapserver-7.4.4/mapscript/perl/$<TARGET_FILE:perlmapscript>".
Call Stack (most recent call first):
  cmake_install.cmake:471 (INCLUDE)
Same thing happens with Java if I enable the compilation flags in Makefile.
Expected result is a successful make install
Any suggestions?
Stéphane Poissant  <https://ca.linkedin.com/in/phanohanover>
Portable: 514-793-3506
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201125/e85f256d/attachment.htm>
More information about the MapServer-users mailing list
