[mapserver-users] Version 7.7 & proj.db
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Nov 24 04:28:58 PST 2020
On 2020-11-24 8:18 a.m., Jeff McKenna wrote:
> On 2020-11-24 8:12 a.m., Jeff McKenna wrote:
>> Master now requires PROJ 7 (and PROJ now requires SQLite, LibTIFF,
>> Curl). The PROJ build process should generate 'proj.db' inside /data,
>> and 'make install' should place that file in something like
>> /usr/local/share/proj/proj.db
>> Make sure that GDAL and MapServer are built with PROJ 7 (7.2.0 is
>> recommended).
>> -jeff
> Be careful also that if you have compiled the GeoTIFF library yourself,
> that it also requires PROJ (and therefore PROJ 7). I've had to
> recompile that on many client systems.
> -jeff
and GDAL 3.2.0 is recommended with PROJ 7.2.0
clear as mud? :)
Hello from the east coast of Canada,
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
