[mapserver-users] Version 7.7 & proj.db
aimdev at mail.com
aimdev at mail.com
Tue Nov 24 06:40:09 PST 2020
Hi
I used
proj-bin/testing,now 7.2.0-1 amd64 [installed]
proj-data/testing,now 7.2.0-1 all [installed,automatic]
libproj-dev/testing,now 7.2.0-1 amd64 [installed,automatic]
and
gdal-bin/testing,now 3.1.4+dfsg-1+b1 amd64 [installed]
gdal-data/testing,now 3.1.4+dfsg-1 all [installed]
libgdal-dev/testing,now 3.1.4+dfsg-1+b1 amd64 [installed]
These are the ones available from the Bullseye repository.
I am not clear where the proj.db file would have been installed, and where it should go / how it is referenced in the MapServer directory structure.
From my point of view the map looks the same as the existing
> On 24 Nov 2020, at 12:28, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> On 2020-11-24 8:18 a.m., Jeff McKenna wrote:
>> On 2020-11-24 8:12 a.m., Jeff McKenna wrote:
>>> Master now requires PROJ 7 (and PROJ now requires SQLite, LibTIFF, Curl). The PROJ build process should generate 'proj.db' inside /data, and 'make install' should place that file in something like /usr/local/share/proj/proj.db
>>> Make sure that GDAL and MapServer are built with PROJ 7 (7.2.0 is recommended).
>>> -jeff
>> Be careful also that if you have compiled the GeoTIFF library yourself, that it also requires PROJ (and therefore PROJ 7). I've had to recompile that on many client systems.
>> -jeff
> and GDAL 3.2.0 is recommended with PROJ 7.2.0
> clear as mud? :)
> Hello from the east coast of Canada,
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201124/67358144/attachment.html>
