[mapserver-users] [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
    Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
    matthew.f.cechini at nasa.gov
    Mon Sep 14 13:35:15 PDT 2020
I don't think that is creating the desired behavior.  According the the WMS specification:
	Zero or more Styles may be advertised for a Layer or collection of layers using <Style> elements, each of which shall have <Name> and <Title> elements.
	The style's Name is used in the Map request STYLES parameter.
Which would look like the following in the Capabilities document for a layer that has two styles:
    <Layer queryable="0" opaque="0" cascaded="0">
        <Name>VIIRS_NOAA20_Thermal_Anomalies_375m_All</Name>
        <Title>Thermal Anomalies and Fires (375m, All, VIIRS, NOAA20)</Title>
        <Style>
            <Name>default</Name>
            <Title>default</Title>
        </Style>
        <Style>
            <Name>blue</Name>
            <Title>blue</Title>
        </Style>
    </Layer>
As far as I can tell/test, the CLASSGROUP configuration doesn't give me this desired behavior.  Note also that the LAYER/METADATA has the following information, which presumably would be duplicated for each supported style:
                "wms_style"                                                    "default"
                "wms_style_default_legendurl_width"     "420"
                "wms_style_default_legendurl_height"    "95"
                "wms_style_default_legendurl_format"    "image/png"
                "wms_style_default_legendurl_href"      "https://..../legends/.....png"
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
On 9/14/20, 11:05 AM, "mapserver-users on behalf of Jörg Thomsen (WhereGroup)" <mapserver-users-bounces at lists.osgeo.org on behalf of joerg.thomsen at wheregroup.com> wrote:
    I guess you are looking für classgroup:
    LAYER
      CLASSGROUP "group1"
      CLASS
        NAME "name1"
        GROUP "group1"
      END
    see https://urldefense.proofpoint.com/v2/url?u=https-3A__mapserver.org_mapfile_class.html&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=oclSQI0C1ThED5G6tbO2HojWNaYEeXUahlcUf1J3xr4&e=
    Jörg
    Am 14.09.20 um 16:56 schrieb Cechini, Matthew F. (GSFC-423.0)[Science
    Systems & Applications, Inc.]:
    > Unfortunately, that’s not the functionality that I’m looking for…
    > What I want is to support “&STYLES=default” or “&STYLES=blue” query
    > parameters resulting in different styling of the same underlying data.
    > Thanks,
    > Matt
    > Matthew Cechini
    > 410.205.6272
    > *From: *"Lime, Steve D (MNIT)" <steve.lime at state.mn.us>
    > *Date: *Monday, September 14, 2020 at 10:49 AM
    > *To: *Matthew Cechini <matthew.f.cechini at nasa.gov>,
    > "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
    > *Subject: *RE: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
    > Names aren’t valid (or useful) at the style-level. If you remove those
    > lines it should work and you’ll get stacked styles for each feature. --Steve
    > *From:*Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications,
    > Inc.] <matthew.f.cechini at nasa.gov>
    > *Sent:* Monday, September 14, 2020 7:27 AM
    > *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>;
    > *Subject:* Re: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
    > We’re using 7.0.1… admittedly a bit of an older version.  Mapserver
    > balks on NAME in the STYLE element in that version.
    > Thanks,
    > Matt
    > Matthew Cechini
    > 410.205.6272
    > <mailto:steve.lime at state.mn.us>>
    > *Date: *Friday, September 11, 2020 at 5:17 PM
    > <mailto:matthew.f.cechini at nasa.gov>>, "mapserver-users at lists.osgeo.org
    > <mailto:mapserver-users at lists.osgeo.org>"
    > <mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>>
    > *Subject: *[EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
    > Hi Matt: Actually that syntax is supported (except for the style NAME
    > attribute) and you can have multiple styles inside a class. What version
    > are you using? --Steve
    > *From:*mapserver-users <mapserver-users-bounces at lists.osgeo.org
    > <mailto:mapserver-users-bounces at lists.osgeo.org>> *On Behalf Of
    > *Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
    > *Sent:* Friday, September 11, 2020 2:37 PM
    > *To:* mapserver-users at lists.osgeo.org
    > *Subject:* [mapserver-users] Multiple Styles for a LAYER/CLASS
    > Greetings,
    >    I would like to provide multiple styles for the same LAYER/CLASS in
    > our mapserver configuration.  Ideally that looks something like this,
    > though of course this syntax isn’t currently supported.
    >     CLASS
    >   NAME "Thermal Anomalies"
    >          STYLE
    >              NAME   'default'
    >              SYMBOL 'circle'
    >              COLOR  240 40 40
    >              OUTLINECOLOR  240 40 40
    >              SIZE 3
    >          END
    >          STYLE
    >              NAME   'blue'
    >              SYMBOL 'circle'
    >              COLOR  0 0 255
    >              OUTLINECOLOR  0 0 255
    >              SIZE 3
    >          END
    >     END
    >    How would I accomplish this given existing functionality?
    > Thanks,
    > Matt
    > Matthew Cechini
    > 410.205.6272
    > https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_mapserver-2Dusers&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=hP2umavasw6yoloBsKZQaLp-TqKJ97ehRA_MPRxtXWA&e=
    Viele Grüße,
    Jörg Thomsen
    Aufwind durch Wissen!
    Jetzt neu: Web-Seminare und Online-Schulungen
    bei der https://urldefense.proofpoint.com/v2/url?u=http-3A__www.foss-2Dacademy.com&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=0IjAFNhghml9HXpToQwMoHRBmVFaoRvVKMN4ftfvJhE&e=
    Jörg Thomsen
    WhereGroup GmbH
    Bundesallee 23
    10717 Berlin
    Germany
    Fon: +49 (0)30 / 5130 278 74
    Fax: +49 (0)30 / 5130 278 11
    https://urldefense.proofpoint.com/v2/url?u=http-3A__www.wheregroup.com&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=wnQQ5nHgsz5qm-sT5nizlY6IsV4Yferbyg5CXYFaEjI&e=
    Geschäftsführer:
    Olaf Knopp, Peter Stamm
    Amtsgericht Bonn, HRB 9885
    Folgen Sie der WhereGroup auf twitter: https://urldefense.proofpoint.com/v2/url?u=http-3A__twitter.com_WhereGroup-5Fcom&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=SlQSg0SzegOVriwtrrKsd6IcV1x4jojuX-rFllLWG98&e=
More information about the MapServer-users
