[mapserver-users] [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Tue Sep 15 00:28:22 PDT 2020
Hi Matt,
this Mapfile
CLASSITEM "POPYTYPE"
CLASSGROUP 'grey'
CLASS
GROUP 'grey'
NAME "Grenze"
EXPRESSION /./
STYLE
OUTLINECOLOR 128 128 128
WIDTH 3
END
END
CLASS
GROUP 'red'
NAME "Grenze"
EXPRESSION /./
STYLE
OUTLINECOLOR 255 0 0
WIDTH 3
END
END
results in this capabilities:
<Layer queryable="0" opaque="0" cascaded="0">
<Name>Staatsgrenze</Name>
<Title>Staatsgrenze</Title>
<Style>
<Name>grey</Name>
<Title>grey</Title>
<LegendURL width="59" height="20">
</LegendURL>
</Style>
<Style>
<Name>red</Name>
<Title>red</Title>
</LegendURL>
</Style>
</Layer>
As in MapServer one symbol in the map can be the result of many combined
style-blocks in the mapfile, you cannot name the styles but you have to
use the claasgroup in the layer and the group-keyword within the the class.
You have to distinguish between the mapfile- and the capabilities-structure.
You only need the wms_style_default_ if you want other than the auto
genrated legend-symbols.
Jörg
Am 14.09.20 um 22:35 schrieb Cechini, Matthew F. (GSFC-423.0)[Science
Systems & Applications, Inc.]:
> I don't think that is creating the desired behavior. According the the WMS specification:
> Zero or more Styles may be advertised for a Layer or collection of layers using <Style> elements, each of which shall have <Name> and <Title> elements.
> The style's Name is used in the Map request STYLES parameter.
> Which would look like the following in the Capabilities document for a layer that has two styles:
> <Name>VIIRS_NOAA20_Thermal_Anomalies_375m_All</Name>
> <Title>Thermal Anomalies and Fires (375m, All, VIIRS, NOAA20)</Title>
> <Style>
> <Name>default</Name>
> <Title>default</Title>
> </Style>
> <Style>
> <Name>blue</Name>
> <Title>blue</Title>
> </Style>
> </Layer>
> As far as I can tell/test, the CLASSGROUP configuration doesn't give me this desired behavior. Note also that the LAYER/METADATA has the following information, which presumably would be duplicated for each supported style:
> "wms_style" "default"
> "wms_style_default_legendurl_width" "420"
> "wms_style_default_legendurl_height" "95"
> "wms_style_default_legendurl_format" "image/png"
> "wms_style_default_legendurl_href" "https://..../legends/.....png"
> Thanks,
> Matt
> Matthew Cechini
> Contractor, Science Systems and Applications, Inc.
> NASA GIBS Systems/Software Engineer
> 410.205.6272
> On 9/14/20, 11:05 AM, "mapserver-users on behalf of Jörg Thomsen (WhereGroup)" <mapserver-users-bounces at lists.osgeo.org on behalf of joerg.thomsen at wheregroup.com> wrote:
> I guess you are looking für classgroup:
> LAYER
> CLASSGROUP "group1"
> CLASS
> NAME "name1"
> GROUP "group1"
> END
> see https://urldefense.proofpoint.com/v2/url?u=https-3A__mapserver.org_mapfile_class.html&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=oclSQI0C1ThED5G6tbO2HojWNaYEeXUahlcUf1J3xr4&e=
> Jörg
> Am 14.09.20 um 16:56 schrieb Cechini, Matthew F. (GSFC-423.0)[Science
> > Unfortunately, that’s not the functionality that I’m looking for…
> > What I want is to support “&STYLES=default” or “&STYLES=blue” query
> > parameters resulting in different styling of the same underlying data.
> > Thanks,
> > Matt
> > Matthew Cechini
> > 410.205.6272
> > *From: *"Lime, Steve D (MNIT)" <steve.lime at state.mn.us>
> > *Date: *Monday, September 14, 2020 at 10:49 AM
> > *To: *Matthew Cechini <matthew.f.cechini at nasa.gov>,
> > "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> > *Subject: *RE: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
> > Names aren’t valid (or useful) at the style-level. If you remove those
> > lines it should work and you’ll get stacked styles for each feature. --Steve
> > *From:*Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications,
> > Inc.] <matthew.f.cechini at nasa.gov>
> > *Sent:* Monday, September 14, 2020 7:27 AM
> > *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>;
> > *Subject:* Re: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
> > We’re using 7.0.1… admittedly a bit of an older version. Mapserver
> > balks on NAME in the STYLE element in that version.
> > Thanks,
> > Matt
> > Matthew Cechini
> > 410.205.6272
> > <mailto:steve.lime at state.mn.us>>
> > *Date: *Friday, September 11, 2020 at 5:17 PM
> > <mailto:matthew.f.cechini at nasa.gov>>, "mapserver-users at lists.osgeo.org
> > <mailto:mapserver-users at lists.osgeo.org>"
> > <mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>>
> > *Subject: *[EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
> > Hi Matt: Actually that syntax is supported (except for the style NAME
> > attribute) and you can have multiple styles inside a class. What version
> > are you using? --Steve
> > *From:*mapserver-users <mapserver-users-bounces at lists.osgeo.org
> > <mailto:mapserver-users-bounces at lists.osgeo.org>> *On Behalf Of
> > *Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
> > *Sent:* Friday, September 11, 2020 2:37 PM
> > *To:* mapserver-users at lists.osgeo.org
> > *Subject:* [mapserver-users] Multiple Styles for a LAYER/CLASS
> > Greetings,
> > I would like to provide multiple styles for the same LAYER/CLASS in
> > our mapserver configuration. Ideally that looks something like this,
> > though of course this syntax isn’t currently supported.
> > CLASS
> > NAME "Thermal Anomalies"
> > STYLE
> > NAME 'default'
> > SYMBOL 'circle'
> > COLOR 240 40 40
> > OUTLINECOLOR 240 40 40
> > SIZE 3
> > END
> > STYLE
> > NAME 'blue'
> > SYMBOL 'circle'
> > COLOR 0 0 255
> > OUTLINECOLOR 0 0 255
> > SIZE 3
> > END
> > END
> > How would I accomplish this given existing functionality?
> > Thanks,
> > Matt
> > Matthew Cechini
> > 410.205.6272
> > mapserver-users mailing list
> > https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_mapserver-2Dusers&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=hP2umavasw6yoloBsKZQaLp-TqKJ97ehRA_MPRxtXWA&e=
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der https://urldefense.proofpoint.com/v2/url?u=http-3A__www.foss-2Dacademy.com&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=0IjAFNhghml9HXpToQwMoHRBmVFaoRvVKMN4ftfvJhE&e=
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.wheregroup.com&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=wnQQ5nHgsz5qm-sT5nizlY6IsV4Yferbyg5CXYFaEjI&e=
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: https://urldefense.proofpoint.com/v2/url?u=http-3A__twitter.com_WhereGroup-5Fcom&d=DwIGaQ&c=ApwzowJNAKKw3xye91w7BE1XMRKi2LN9kiMk5Csz9Zk&r=OipIn4BZYBcdlsutC4b_bGavezJwpYfx1lCdvhPIEUg&m=ugMtvhucImNS0kQeKIeO0NPhBwon8nGMIeDOOIfD5Y4&s=SlQSg0SzegOVriwtrrKsd6IcV1x4jojuX-rFllLWG98&e=
Viele Grüße,
Jörg Thomsen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
www.wheregroup.com
Geschäftsführer:
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users
