[mapserver-users] Coordinates shifted for EPSG:28992
Just van den Broecke
justb4 at gmail.com
Fri Sep 18 01:37:34 PDT 2020
Hi Even,
(Sorry mispelled your name in last email).
On 17-09-20 21:54, Even Rouault wrote:
> On jeudi 17 septembre 2020 21:20:56 CEST Just van den Broecke wrote:
> > Hi Evan,
> > Thanks for your quick reply! Will try out other combinations of proj and
> > MS with custom compiles and let you know here.
> > I did not quite grasp your last paragraph, but I am no expert in the
> > subject. For The Netherlands the expert is Lennard Huisman, formerly
> > from Dutch Kadaster. IMHO he donated to proj the most accurate
> > transformation with an NTV2 grid for the "real" Dutch coordinate system
> > (another EPSG code), which was set out by hand via triangulation.
> I suspect you're speaking about the rdtrans2008 or rdtrans2018 grids
> that are for transformations between the Amersfoort datum and ETRS89. I
> can't see any grids between Amersfoort and WGS84 registered in EPSG,
> because of the time-dependent nature of WGS84 (well you could use the
> grids for transformation to WGS84 if you're ready to consider ETRS89 ==
> WGS84 for your purposes).
Yes, referring to those grids, indeed using ETRS89 for the reasons you
give (Eurasian tectonic plate I think). A sidestep.
EPSG:28992 is accurate enough for our purposes and easier to deploy.
Jeff gave some MS-Proj version combination compile hints we are going to
try out (thanks Jeff!). Thanks again, Even, also for your hard work on Proj.
Best,
Just
> Spatialys - Geospatial professional services
> http://www.spatialys.com
