[mapserver-users] Coordinates shifted for EPSG:28992
Just van den Broecke
justb4 at gmail.com
Wed Sep 23 11:52:54 PDT 2020
Hi all, in particular Even, Jeff,
Confirmed that this (no coordinate shift in MapServer renders for
EPSG:4326 to EPSG:28992) version-combination works on Ubuntu 20.4 with
custom compiles:
- MapServer 7.4.3 and Proj 5.2 and GDAL (I think) 3.0.4 (default on
Ubuntu 20.4) **
As Even replied (and Jeff suggested):
"...you should try to stick to one of the following combinations:
- With MapServer 7.4 or 7.6: GDAL 2.x + PROJ 5.x
- With MapServer >= 7.6: GDAL 3.x + PROJ >= 6.x"
** I am reporting/replying as a proxy for a customer who does the custom
compiles. They decided to stick with the default "apt" installs on clean
Ubuntu 20.4 (without Ubuntu-GIS PPA), that is: MapServer 7.4.3, Proj
6.3.1, GDAL 3.0.4. Solving it, by adding the full, explicit "init" proj
string of EPSG:28992 for each Layer in the MS mapfile.
Sorry that I could not be of more help. Think we all should be, at least
I am, grateful with the boost on Proj-development from (20 years?)
Proj.4 on! I am close to the Dutch OSGeo community, so will keep you
updated.
Best,
Just
On 18-09-20 10:37, Just van den Broecke wrote:
> Hi Even,
> (Sorry mispelled your name in last email).
> On 17-09-20 21:54, Even Rouault wrote:
>> On jeudi 17 septembre 2020 21:20:56 CEST Just van den Broecke wrote:
>> > Hi Evan,
>> > Thanks for your quick reply! Will try out other combinations of
>> proj and
>> > MS with custom compiles and let you know here.
>> > I did not quite grasp your last paragraph, but I am no expert in the
>> > subject. For The Netherlands the expert is Lennard Huisman, formerly
>> > from Dutch Kadaster. IMHO he donated to proj the most accurate
>> > transformation with an NTV2 grid for the "real" Dutch coordinate
>> system
>> > (another EPSG code), which was set out by hand via triangulation.
>> I suspect you're speaking about the rdtrans2008 or rdtrans2018 grids
>> that are for transformations between the Amersfoort datum and ETRS89.
>> I can't see any grids between Amersfoort and WGS84 registered in EPSG,
>> because of the time-dependent nature of WGS84 (well you could use the
>> grids for transformation to WGS84 if you're ready to consider ETRS89
>> == WGS84 for your purposes).
> Yes, referring to those grids, indeed using ETRS89 for the reasons you
> give (Eurasian tectonic plate I think). A sidestep.
> EPSG:28992 is accurate enough for our purposes and easier to deploy.
> Jeff gave some MS-Proj version combination compile hints we are going to
> try out (thanks Jeff!). Thanks again, Even, also for your hard work on
> Proj.
> Best,
> Just
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
