[mapserver-users] Image Styling Question
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Thu Sep 24 23:55:43 PDT 2020
interesting.
I think the best way would be to generate single TIFFs for each
classification region and use them in different grouped layers.
Alternativly you could also use different grouped layers. In each layer
you use the whole tiff and use mask layer created with the filtered shp.
Jörg
Am 24.09.20 um 21:33 schrieb Brian Walawender - NOAA Federal:
> Hello,
> I have a GeoTiff containing temperature readings across the US that I
> need to apply a styling to. The challenge is that the styling will vary
> based on the geographic region that the pixel is located in. I have
> both a GeoTiff and a shapefile available that delineate the
> classification regions. How do I specify these regions in my CLASS
> definitions in my mapfile?
> Thanks.
> bw
> Brian Walawender
> Chief, Systems and Facilities Division (SFD)
> NOAA/National Weather Service
> Central Region Headquarters
> 816-268-3114 - Office
> 816-805-6497 - Cell
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
