[mapserver-users] OGR Geojson error
Weisbender, Eric
Weisbend at WAPA.GOV
Fri Sep 25 07:27:34 PDT 2020
Hello List,
I have two sources of geojson data in my map file. One works fine the other does not. The one that works streams into the browser when I go to it directly. The other source downloads a file. The one that does not work I get the following MapServer error. Also the geojson sources are listed below. The layer defs are the same in the mapfile.
Thanks in advance for your help.
Error:
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `fire_nifc_point . File not found or unsupported format. Check server logs.
Works: http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson
No Worky: http://opendata.arcgis.com/datasets/68637d248eb24d0d853342cba02d4af7_0.geojson
Eric Weisbender | GIS Program Lead
Western Area Power Administration | Headquarters
(O) 720.962.7280 | weisbend at wapa.gov<mailto:weisbend at wapa.gov>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200925/2305cf12/attachment.html>
