[mapserver-users] OGR Geojson error
b.j.kobben at utwente.nl
Sat Sep 26 01:52:30 PDT 2020
It might be simply that file names beginning with a number are always a bad idea, because several libs and systems out there have problems with it...?
Barend Köbben
On 25/09/2020, 16:45, "mapserver-users on behalf of Weisbender, Eric" <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> on behalf of Weisbend at WAPA.GOV<mailto:Weisbend at WAPA.GOV>> wrote:
Hello List,
I have two sources of geojson data in my map file. One works fine the other does not. The one that works streams into the browser when I go to it directly. The other source downloads a file. The one that does not work I get the following MapServer error. Also the geojson sources are listed below. The layer defs are the same in the mapfile.
Thanks in advance for your help.
Error:
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `fire_nifc_point . File not found or unsupported format. Check server logs.
Works: http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson
No Worky: http://opendata.arcgis.com/datasets/68637d248eb24d0d853342cba02d4af7_0.geojson
Eric Weisbender | GIS Program Lead
Western Area Power Administration | Headquarters
(O) 720.962.7280 | weisbend at wapa.gov<mailto:weisbend at wapa.gov>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200926/764ab6dc/attachment.html>
